JoyStick Arduino Mega and Ethernet Shield sending OSC messages
Hi all,
I'm very new to Arduino programming and am having issues with noise interference on my digital pins.
I have an Arduino Mega and an Ethernet shield I'm trying to have a 4 micro switch Joystick (with a 5th switch for the button) control a UI in Touchdesigner via OSC messages from the Arduino. I'm doing this by having the digital input pins (23,25,27,29,31) send a 1 when it receives high voltage from the NO pin of each different micro switch. For some reason there is a lot of digital noise causing the pins to send false 1's to Touchdesigner. I'm not very good with electronics and don't have an understanding if my circuit is correct or if I need to put resistors in line before each pin to mitigate this. I also don't have a clear schematic written out but will provide pictures and my code for a clearer picture.
I have a 5v PSU sending positive to all of the common pins on the microswitch and the negative to one of the ground pins on the Arduino mega I'm not sure if this can indicate if my circuit is incorrect or not.
Another thing to note that when each pin is connect to a multimeter the voltage for switch works perfectly as in 0v for nothings and 5v when activated.
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <OSCMessage.h>
EthernetUDP Udp;
// Arduino's IP
IPAddress ip(192, 168, 1, 105);
// Destination IP
IPAddress outIp(192, 168, 1, 2);
const unsigned int outPort = 8001;
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
  Ethernet.begin(mac, ip);
  Udp.begin(8888);
  // Initialize digital pins as inputs
  pinMode(23, INPUT);
  pinMode(25, INPUT);
  pinMode(27, INPUT);
  pinMode(29, INPUT);
  pinMode(31, INPUT);
  sendOscMessage(23, "/select");
  sendOscMessage(25, "/left");
  sendOscMessage(27, "/right");
  sendOscMessage(29, "/up");
  sendOscMessage(31, "/down");
void sendOscMessage(int pin, const char* address) {
  OSCMessage msg(address);
  int value = digitalRead(pin);
  msg.add(value);
  Udp.beginPacket(outIp, outPort);
  msg.send(Udp); // send the bytes to the SLIP stream
  Udp.endPacket(); // mark the end of the OSC Packet
  msg.empty(); // free space occupied by message
  // Increased debouncing delay
  delay(20); // Adjusted delay to better mitigate noise.
unnamed (4)
Screenshot 2024-04-04 123745
Run your switch data through a debounce algorithm.
For example, read a single switch 5 times in a row at 5 millisecond intervals. If all the readings are the same then send a single reading via OSC. If you see a mixture of 0 and 1 then it means the switch is bouncing and the data should be ignored.
