I'm trying to use a Joystick to control an LED. I have 2 sets of code I am trying to combine so that I get the correct output on my serial monitor (from Code 1), while my Max 2719 provides a visual representation (which works with Code 2). I've tried combining the 2 codes, which compiles correctly, but I get no LED output. Is there something I'm overlooking in my attempted combination?
Code 1:
int X = A1;
int Y = A0;
int SwitchButton = 2;
int X_axis_location = 0;
int Y_axis_location = 0;
int SW_status = 0;
// initialize serial communications at 9600 bps:
pinMode(X, INPUT);
pinMode(Y, INPUT);
pinMode(SwitchButton, INPUT_PULLUP); // it is "input" and "with pull-up resistor
// since we are using the build-in pull-up resistor
// when the switch is open, the pin "SwitchButton" read high voltage
// when the switch is closed, the pin "SwitchButton" read low voltage
delay(3000);
X_axis_location = analogRead(X);
Y_axis_location = analogRead(Y);
SW_status = digitalRead(SwitchButton);
Serial.print("X axis location of the JoyStick ");
Serial.print('\n');
Serial.print(X_axis_location);
Serial.print('\n');
Serial.print("Y axis location of the JoyStick ");
Serial.print('\n');
Serial.print(Y_axis_location);
Serial.print('\n');
Serial.print("Voltage of the SW read by Arduino ");
Serial.print('\n');
Serial.println(SW_status);
Serial.print('\n');Serial.print('\n');Serial.print('\n');
Code 2:
int UD = 0;
int LR = 0; //Setting up controller//
#include "LedControl.h" // need the library
LedControl lc=LedControl(8,10,9,1); //10 is to CLOCK, 9 = CS, 8=DIN//
lc.shutdown(0,false); // turn off power saving, enables display
lc.setIntensity(0,8); // sets brightness (0~15 possible values)
lc.clearDisplay(0); // clear screen
UD = analogRead(A0);
LR = analogRead(A1);
char x_translate = map(LR, 1023, 0, 7, 0); //This maps the values//
char y_translate = map(UD, 1023, 0, 0, 7);
Serial.print("UD = ");
Serial.print(UD, DEC);
Serial.print(", LR = ");
Serial.print(LR, DEC);
Serial.print(", x = ");
Serial.print(x_translate, DEC);
Serial.print(", y = ");
Serial.println(y_translate, DEC);
// not in shutdown mode
lc.clearDisplay(0);
lc.setLed(0,x_translate,y_translate,true);
delay(150); //adjust delay to get your joystick correct//
Attempted Combination:
int X = A1;
int Y = A0;
int SW_status = 0;
pinMode(X, INPUT);
pinMode(Y, INPUT);
lc = LedControl(8,10,9,1);
delay(3000);
Serial.print('\n');
Serial.print('\n');
Serial.print('\n');
Serial.print('\n');
Serial.print('\n');
char x_translate = map(X, 1023, 0, 7, 0);
char y_translate = map(Y, 1023, 0, 0, 7);
lc.clearDisplay(0);
delay(150);
