Joystick dpad buttons with 4021 Shift Register not recognized
Hi, I'm making a usb gamepad with dpad and 4 buttons using the Joystick library, all buttons are running through a 4021 shift register, on an Arduino Pro Micro.
As you can see below, I've basically combined the shift register example from here:(Parallel to Serial Shifting-In with a CD4021BE | Arduino) with the Joystick example for a gamepad, adding a few more buttons.
I'm testing my results through my laptop's game controller properties.
My issue is that while the additional buttons work, the laptop won't recognize the Dpad buttons. If I change the Joystick settings to be no xAxis or yAxis and just 8 buttons, they all are recognized. Also, when I initially tried the Joystick example with buttons on pins my laptop recognized it as the dpad.
Another issue is that when I jiggle the latch, clock, and data wires, the laptop's dpad recognition DID move. Changing which pins I used didn't fix this.
Any thoughts?
//Shift Register Shit:
int clockPin = 7;
int latchPin = 8;
int dataPin = 9;
byte switchVar1 = 72;
char note2sing[] = {
  'R', 'L', 'D', 'U', 'T', 'E', 'B', 'A'};
//Joystick Shit:
#include <Joystick.h>
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,JOYSTICK_TYPE_GAMEPAD,
  4, 0,                  // Button Count, Hat Switch Count
  true, true, false,     // X and Y, but no Z Axis
  false, false, false,   // No Rx, Ry, or Rz
  false, false,          // No rudder or throttle
  false, false, false);  // No accelerator, brake, or steering
//Shift Register Setup:
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, INPUT);
//Joystick Setup:
  Joystick.begin();
  Joystick.setXAxisRange(-1, 1);
  Joystick.setYAxisRange(-1, 1);
//Joystick: Last state of the buttons
int lastButtonState[8] = {0,0,0,0,0,0,0,0};
//Shift Register get data:
  digitalWrite(latchPin,1);
  delayMicroseconds(20);
  digitalWrite(latchPin,0);
  switchVar1 = shiftIn(dataPin, clockPin);
//switchVar1 = ~switchVar1;   //THIS IS THE SHIT THAT INVERTS THE BUTTON PRESS
//Serial for debugging
//  Serial.println(switchVar1, BIN);
//  for (int n=0; n<=7; n++)
//    if (switchVar1 & (1 << n) ){
//      Serial.println(note2sing[n]);
//Serial.println("-------------------");
//delay(500);
//Joystick assign buttons
  Joystick.setButton(0, !bitRead(switchVar1, 7));
  Joystick.setButton(1, !bitRead(switchVar1, 6));
  Joystick.setButton(2, !bitRead(switchVar1, 5));
  Joystick.setButton(3, !bitRead(switchVar1, 4));
  Joystick.setButton(4, !bitRead(switchVar1, 3));
  Joystick.setButton(5, !bitRead(switchVar1, 2));
  Joystick.setButton(6, !bitRead(switchVar1, 1));
  Joystick.setButton(7, !bitRead(switchVar1, 0));
//Joystick do Joystick shit
for (int index = 0; index < 8; index++)
    int currentButtonState = !digitalRead(index + 4);
    if (currentButtonState != lastButtonState[index])
      switch (index) {
        case 0: // UP
          if (currentButtonState == 1) {
            Joystick.setYAxis(-1);
            Joystick.setYAxis(0);
        case 1: // RIGHT
            Joystick.setXAxis(1);
            Joystick.setXAxis(0);
        case 2: // DOWN
            Joystick.setYAxis(1);
        case 3: // LEFT
            Joystick.setXAxis(-1);
        case 4: // FIRE
          Joystick.setButton(0, currentButtonState);
        case 5: //
          Joystick.setButton(1, currentButtonState);
        case 6: //
          Joystick.setButton(2, currentButtonState);
        case 7: //
          Joystick.setButton(3, currentButtonState);
      lastButtonState[index] = currentButtonState;
byte shiftIn(int myDataPin, int myClockPin) {
  int i;
  int temp = 0;
  int pinState;
  byte myDataIn = 0;
  pinMode(myClockPin, OUTPUT);
  pinMode(myDataPin, INPUT);
  for (i=7; i>=0; i--)
    digitalWrite(myClockPin, 0);
    delayMicroseconds(0.2);
    temp = digitalRead(myDataPin);
    if (temp) {
      pinState = 1;
      myDataIn = myDataIn | (1 << i);
    else {
      pinState = 0;
    digitalWrite(myClockPin, 1);
  return myDataIn;
It appears you have more then one problem. Start by posting a schematic, not a frizzy thing. Jiggling tells me you got bad connections and the clock and data especially give you lots of garbage. No way of knowing what happened.
I don't really have a schematic to post. In any event, as I said the buttons function as buttons perfectly fine, when I alter the code for that case. So that would tell me that the physical connections are good. Perhaps you can tell me what specifically you need to know about the connections.
