"jumping the case label"?
Hi - small question here: I was working on a project yesterday where I was using a switch/case statement and attempting to define a local var in several of the cases - something like
case: 1
  // do some stuff
case 2:
  int p = resultOfFunctionCall();
  //do something with p
case 3:
  int p = resultOfOtherFunctionCall();
  //do something else with p
I was getting a compile error something like "jumping the case label" related to my local var. I resolved it by declaring the var inside the switch but outside any case. I am not returning the var at the end of the switch or anything like that so I wondered why the compiler would complain.
Is there some rule about not declaring local vars in a case statement?
tx
-Roy
In C and C++, variables must have unique names within the same code block; code blocks are statements enclosed by curly braces . You could add braces around your code as follows:
case 2:
{ int p = resultOfFunctionCall();
thanks. that makes sense. The "jumping the case label" msg didn't
I've got the same problem, and tried adding curly brackets as given below, but I still get the error. Does anyone know why?
case 1:
int ledLevel = random(0,ledCount);
Post your entire Sketch. Please use code tags.
Looking just at the code snippet you posted, I would guess that you do not have the same problem. You have a different, but similar, problem.
As Coding Badly suggests, you need to post more of your code, and the EXACT error message.
