Just want to fade an LED in with button and back out
Hi I just want to program my Arduino to fade LEDs in with one button press and then stay on. Then with the next button press I want it to fade out and stay off. Any tips or thoughts would be appreciated.
const int buttonPin = A0;     // the number of the pushbutton pin
const int ledPin =  5;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
      // sets the value (range from 0 to 255):
      analogWrite(ledPin, fadeValue);
      // wait for 30 milliseconds to see the dimming effect
      delay(30);
  else {
    // turn LED off:
    for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
      delay(30);
i think that this line is your problem
you have your pushbutton on an analog pin, and you are calling digitalRead later on. Instead of using pin A0 you need to use a digital pin instead.
connect one side of button to a digital input pin, run a resistor to ground on that same side, and the other side of button to +5v
thanks ill try that. All its doing is when I hold the button it fades in over and over again and when the button is released its the opposite whichi I guess is what its coded to do. lol. i have a long ways to go, feeling retarded.... :angry:
also i notice that you don't have a variable for the button state or the previous button state.. check out this tut
