Helo,
I am using the following code for the K33 BLG sensor and a Arduino Mega 2560. The Co2 and RH values are shown, but Temp is 0.00C.
May someone can have a look at the code? I would like to find out if it is a code or sensor problem.
#include <Wire.h>
// We will be using the I2C hardware interface on the Arduino in
// combination with the built‐in Wire library to interface.
// Arduino analog input 5 ‐ I2C SCL
// Arduino analog input 4 ‐ I2C SDA
In this example we will do a basic read of the CO2 value and checksum verification. For more advanced applications please see the I2C Comm guide.
int co2Addr = 0x68;
//int co2Addr = 0x7F;
// This is the default address of the CO2 sensor, 7bits shifted left.
Wire.begin ();
pinMode(13, OUTPUT); // We will use this pin as a read‐indicator
Serial.println("What a wonderful day, to read atmospheric CO2 concentrations!");
// Function : void wakeSensor()
// Executes : Sends wakeup commands to K33 sensors.
// Note : THIS COMMAND MUST BE MODIFIED FOR THE SPECIFIC AVR YOU ARE USING // THE REGISTERS ARE HARD‐CODED
void wakeSensor() {
// This command serves as a wakeup to the CO2 sensor, for K33‐ELG/BLG Sensors Only
// You'll have the look up the registers for your specific device, but the idea here is simple:
// 1. Disabled the I2C engine on the AVR
// 2. Set the Data Direction register to output on the SDA line
// 3. Toggle the line low for ~1ms to wake the micro up. Enable I2C Engine
// 4. Wake a millisecond.
TWCR &= ~(1 << 2); // Disable I2C Engine
DDRC |= (1 << 4); // Set pin to output mode
PORTC &= ~(1 << 4); // Pull pin low
delay(1);
PORTC |= (1 << 4); // Pull pin high again
TWCR |= (1 << 2); // I2C is now enabled
delay(1);
// Function : void initPoll()
// Executes : Tells sensor to take a measurement.
// Notes
void initPoll() {
Wire.beginTransmission(co2Addr);
Wire.write(0x11);
Wire.write(0x00);
Wire.write(0x60);
Wire.write(0x35);
Wire.write(0xA6);
Wire.endTransmission();
delay(20);
Wire.requestFrom(co2Addr, 2);
byte i = 0;
byte buffer[2] = {0, 0};
while (Wire.available()) {
buffer[i] = Wire.read();
i++;
// Function : double readCo2()
// Returns : The current CO2 Value, -1 if error has occured
double readCo2() {
int co2_value = 0;
// We will store the CO2 value inside this variable. digitalWrite(13, HIGH);
// On most Arduino platforms this pin is used as an indicator light.
/* Begin Write Sequence */
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x08);
Wire.write(0x2A);
We wait 10ms for the sensor to process our command.
The sensors's primary duties are to accurately
measure CO2 values. Waiting 10ms will ensure the
data is properly written to RAM
delay(20);
/* Begin Read Sequence */
Since we requested 2 bytes from the sensor we must
read in 4 bytes. This includes the payload, checksum,
and command status byte.
Wire.requestFrom(co2Addr, 4);
byte i = 0;
byte buffer[4] = {0, 0, 0, 0};
Wire.available() is not nessessary. Implementation is obscure but we leave it in here for portability and to future proof our code
i++;
co2_value = 0;
co2_value |= buffer[1] & 0xFF;
co2_value = co2_value << 8;
co2_value |= buffer[2] & 0xFF;
byte sum = 0;
sum = buffer[0] + buffer[1] + buffer[2];
if (sum == buffer[3]) {
// Success!
digitalWrite(13, LOW);
//Checksum Byte
//Byte addition utilizes overflow
return ((double) co2_value / (double) 1);
else {
// Failure!
Checksum failure can be due to a number of factors,
fuzzy electrons, sensor busy, etc.
return (double) -1;
// Function : double readTemp()
// Returns : The current Temperture Value, -1 if error has occured
double readTemp() {
int tempVal = 0;
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x12);
Wire.write(0x34);
delay(20);
byte i = 0;
i++;
tempVal = 0;
tempVal |= buffer[1] & 0xFF;
tempVal = tempVal << 8;
tempVal |= buffer[2] & 0xFF;
byte sum = 0;
//Checksum Byte
return ((double) tempVal / (double) 100);
else {
return -1;
// Function : double readRh()
// Returns : The current Rh Value, -1 if error has occured
double readRh() {
int tempVal = 0;
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x14);
Wire.write(0x36);
delay(20);
byte i = 0;
i++;
tempVal = 0;
byte sum = 0;
//Checksum Byte
return (double) tempVal / (double) 100;
else {
return -1;
// We keep the sample period >25s or so, else the sensor will start ignoring sample requests. wakeSensor();
initPoll();
delay(16000);
wakeSensor();
double tempValue = readTemp();
delay(20);
wakeSensor();
double rhValue = readRh();
delay(20);
wakeSensor();
double co2Value = readCo2();
if (co2Value >= 0) {
Serial.print("CO2: ");
Serial.print(co2Value);
Serial.print("ppm Temp: ");
Serial.print(tempValue);
Serial.print("C Rh: ");
Serial.print(rhValue);
Serial.println("%");
else {
Serial.println("Checksum failed / Communication failure");
delay(9000);
