Keep Temperature Down for Outdoor Project
I live in Central Texas, and I built a small outdoor project that uses a BLE Enabled microcontroller (nRF52) to transmit data inside of an outdoor enclosure. The enclosure has a small solar panel velcro'ed on top of it that keeps the unit powered (with a LiPo battery inside of the enclosure).
The summers here get VERY hot, and we get freezing temperatures a few times a year, too (lovely). These enclosures will be inside of a garden where they get full sun most of the time.
So, my question is, how would I keep the operating temperatures low enough so that I don't fry the electronics inside of these boxes (including the battery), but still leave enough clearance from the antenna so that I can get full signal strength. The antenna part of the PCB (see link above).
I've considered potting everything with the exception of the antenna, but it would be nice to keep enough of the electronics exposed so that I can take it out if I need to.
Potting would be the worst thing you can do. That stops ALL air circulation around your components and they are all designed to have air to conduct any heat away from them.
All the Arduino components have been subjected to much higher heat during the manufacturing processes. The only problem will be a battery and you will have to find the temperature ratings for that and then decide what to do.
Paul
I've seen the outside of some black enclosures (not the polycase... haven't tested that yet) get to up to 170F. Having said that, I got the datasheet for the battery (https://cdn-shop.adafruit.com/product-files/1578/C1854+PKCell+Datasheet+Li-Polymer+503035+500mAh+3.7V+with+PCM.pdf).
It says charging temp between 0-45C and discharge -20-60C. How would I protect the battery from getting too hot inside of the enclosure? I also have another component that has an operating temperature between -40-85C which should be ok; however, I don't like getting that close to the max operating temperature.
Thank you!
You could simply put the battery in the ground.. 12 inches down and it will be in a very stable temperature environment.
Any other suggestions? Ideally I would like to keep the battery in the enclosure, but if I have to I can wire it up to go underground. I assume putting it underground means I would need to pot the battery right?
Maybe I'm just being paranoid. I'm sure I'm not the only one to run a sealed polycase enclosure with a LiPo battery outside. The Adafruit batteries come with over/under charge protection, and the solar charger is rated for fairly high temperatures (Solar Lipo Charger (3.7V) - DFRobot).
To protect against condensation, I plan on putting silica gel in the enclosure and spraying the entire circuit with Corrosion X.
Is there anything else I should consider? Window Tint on the inside of the enclosure (it's clear plastic).?
All you need is shade/water shedding roof and plenty of air circulation. The electronics will be fine, even at 120F.
The far more serious problem is moisture getting into the electronics via condensation. That is very difficult to avoid, but it helps to use conformally coated PCBs. Nail polish works as a coating.
I've posted a picture of my setup before I start putting it together. Do you think an oversized solar panel (as pictured) would be enough shade? I purchased those vents from polycase. They are supposed to provide circulation I assume putting it on the bottom would allow condensation to leak out.
I planned on using Corrosion X on the PCB, but I also have conformal coating as well. Do you think this will work? I've had my project boxes out for a few months prior, and I had condensation build up; however, the electronics were ok due to the Corrosion X.
shade will be the best first step.
Under ground does not mean in contact with dirt. Bury a 5 gallon bucket and you can install your electronics in that. Put drainage holes in the bottom. the thermal mass of the ground, in shade will go a long way to stabilizing the temperature.
You can cover part of your enclosure and dip water on it infrequently. Evaporation will cause cooling.
if you want to experiment, get some of these DS18B20 sensors on 1 meter wires and bury one, put on in a bucket, put one in a jar and cover with a paper towel and dip water on it, a few drops an hour. it would be interesting to see the results.
Great advice all. I was hoping the solution would be similar to the solar lights you buy from Home Depot, but it sounds like it's more complicated than that.
I think what I'm going to try is to first use the polycase I purchased and bury as much as I can of it (about half) in the ground (with contact to dirt). I'll have to run a PG Gland outside of the enclosure so that I can run my soil moisture sensor and wire for the solar panel. I will then stick the small solar panel on top with velcro.
For moisture, I'm going to try silica gel; however, I won't be able to vent the enclosure.
It's not necessarily direct sunlight on the entire enclosure, but I'm hoping the ground and small solar panel (with velcro between) supplies some shade/heat dissipation. I'm also going to add a small TMP36 to my boards to measure enclosure temp. If I see things getting too hot during the summer months, maybe a valve box will work (one of those small round ones). They are fairly cheap and I can run the solar panel wires/soil moisture sensor out of the top.
Any thoughts on that?
Obviously, the valve box I think is probably the "safest" since I can velcro all of it top the top of the lid (and I can vent for soil moisture), but I'm hoping just halfway burying the sensor is enough
I just built a very similar device and ran it all summer long but ran into the same overheating issue right off the bat. As soon as the sun hit the enclosure, the internal temperature climbed from ambient high 70's to almost 100 really quickly. My simple solution was to wrap the nearest object in tin foil (an old dust bin) and simply laid it over the top of my box. The internal temp went right back down to near ambient almost as fast as it spiked.
I realize it's ugly and makeshift, but it worked perfectly all summer. For next summer, I plan to separate the temp/humidity/pressure sensor from the main box and fashion a simple roof for both out of something highly reflective. Either sheet metal or again, something wrapped in tin foil.
The clear window will work like a solar oven - with a bit of luck you might be able to bake bread in it.
The tin foil is a good start
I would put an enclosure around the case - light color or real shiny depending on what your base material is - needs to be open at the top and bottom to work like a chimney to let the hot air out the top - I would put some sort of roof on the top to keep rain out - you could put the solar cell on the roof
For reference see how tradional weather stations are built - white box - louvered sides for air flow
I guess I am a bit reluctant to the burial thing - but a bucket of of sort with holes in the bottom to let any water drain out with your box in the center of the bucket - doubt would need to have much soil on the top to work
Good luck
Is it always powered on and therefore self heating? Then an inverted bucket type of container is great to keep moisture out. The higher temperature inside the container and even higher of the PCB itself means you can never get condensation. Note that higher here means no more than 1-2 degrees, which is enough.
In summer: yes, shade it. Place a second, larger container around it that's completely open from the bottom. Solar cells on top of that. Of course a white colour or even silver would do best to keep the heat away.
I'd be very worried about moisture when using an underground contraption. It'd be at 100% humidity at all times in there. I wonder if in that situation you can even rely on self heating to keep th
Do a bit of research on weather stations and see what the enclosures look for outside temperature sensing. We use to call them bird houses but that was a local slang name for them. Try this link for a start:
https://www.homedepot.com/p/La-Crosse-Technology-Sensor-Protection-Shield-with-Mount-925-1418/300324769?mtc=Shopping-B-F_Brand-G-Multi-NA-Multi-NA-Feed-PLA-NA-NA-Catchall_PLA&cm_mmc=Shopping-B-F_Brand-G-Multi-NA-Multi-NA-Feed-PLA-NA-NA-Catchall_PLA-71700000014585962-58700001236285396-92700010802552436&gclid=EAIaIQobChMIhoi119_y5QIVS5yzCh07pQgoEAQYBSABEgJp2vD_BwE&gclsrc=aw.ds
Good Luck & Have Fun!
Gil
