I am trying to use the Keyboard library to type on my laptop when I swipe an RFID tag but it says I don't have the library
C:\Users\Luke\Documents\my code\Arduino\ArduinoRFIDSystem\ArduinoRFIDSystem.ino: In function 'void setup()':
C:\Users\Luke\Documents\my code\Arduino\ArduinoRFIDSystem\ArduinoRFIDSystem.ino:45:5: error: 'Keyboard' was not declared in this scope
Keyboard.begin();
C:\Users\Luke\Documents\my code\Arduino\ArduinoRFIDSystem\ArduinoRFIDSystem.ino: In function 'void loop()':
C:\Users\Luke\Documents\my code\Arduino\ArduinoRFIDSystem\ArduinoRFIDSystem.ino:90:12: error: 'Keyboard' was not declared in this scope
Keyboard.print("You pressed the button ");
exit status 1
Compilation error: 'Keyboard' not found. Does your sketch include the line '#include <Keyboard.h>'?
* Read a card using a mfrc522 reader on your SPI interface
* Pin layout should be as follows (on Arduino Uno):
* MOSI: Pin 11 / ICSP-4
* MISO: Pin 12 / ICSP-1
* SCK: Pin 13 / ISCP-3
* SS/SDA: Pin 10
* RST: Pin 9
#include <SPI.h>
#include <RFID.h>
#define SS_PIN 10
#define RST_PIN 9
RFID rfid(SS_PIN,RST_PIN);
int led = 7;
int power = 8;
int serNum[5];
int cards[][5] = {
{108, 98, 198, 56, 240}
bool access = false;
void setup(){
SPI.begin();
rfid.init();
Keyboard.begin();
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
void loop(){
if(rfid.isCard()){
if(rfid.readCardSerial()){
Serial.print(rfid.serNum[0]);
Serial.print(" ");
Serial.print(rfid.serNum[1]);
Serial.print(" ");
Serial.print(rfid.serNum[2]);
Serial.print(" ");
Serial.print(rfid.serNum[3]);
Serial.print(" ");
Serial.print(rfid.serNum[4]);
Serial.println("");
for(int x = 0; x < sizeof(cards); x++){
for(int i = 0; i < sizeof(rfid.serNum); i++ ){
if(rfid.serNum[i] != cards[x][i]) {
access = false;
access = true;
if(access) break;
if(access){
Serial.println("Welcome!");
digitalWrite(led, HIGH);
digitalWrite(power, HIGH);
digitalWrite(power, LOW);
Serial.println("Not allowed!");
rfid.halt();
