I got an Arduino Pro Micro and rotary controller with a view to making a USB volume control. Naively, I thought I could simply use Keyboard.write() to send the scan codes for the multimediia keys (Mute 0xE2, Volume Up 0xE9, Volume Down 0xEA) but it seems as though Keyboard.write() treats everything above 128 as modifier keys. Can somebody kindly suggest how I can do it without modifying the standard library?
size_t Keyboard_::write(uint8_t c)
uint8_t p = press(c); // Keydown
release(c); // Keyup
return p; // just return the result of press() since release() almost always returns 1
calls directly press(c) and the press function does a check on the param if (k >= 136) {k = k - 136;...
size_t Keyboard_::press(uint8_t k)
uint8_t i;
if (k >= 136) { // it's a non-printing key (not a modifier)
k = k - 136;
} else if (k >= 128) { // it's a modifier key
_keyReport.modifiers |= (1<<(k-128));
k = 0;
} else { // it's a printing key
k = pgm_read_byte(_asciimap + k);
if (!k) {
setWriteError();
return 0;
if (k & 0x80) { // it's a capital letter or other character reached with shift
_keyReport.modifiers |= 0x02; // the left shift modifier
k &= 0x7F;
// Add k to the key report only if it's not already present
// and if there is an empty slot.
if (_keyReport.keys[0] != k && _keyReport.keys[1] != k &&
_keyReport.keys[2] != k && _keyReport.keys[3] != k &&
_keyReport.keys[4] != k && _keyReport.keys[5] != k) {
for (i=0; i<6; i++) {
if (_keyReport.keys[i] == 0x00) {
_keyReport.keys[i] = k;
if (i == 6) {
setWriteError();
return 0;
sendReport(&_keyReport);
return 1;
and at the end does the sendReport(&_keyReport);
if you could call sendReport with a custom crafted _keyReport then you could may be work your way around this, but as it's a private method, this won't work.
So this is the function that gets called ultimately to pass the keys. its code is
so may be you can work your way by subclassing and finding the right way to setup the keys for your code and call in your class HID().SendReport([i][color=pink]something goes here[/color][/i]);...
