The Capslock flag is kept by the operating system so all keyboards control the same Capslock. The USB standard includes regular and locking Caps Lock keys. I think that, possibly, if you 'press' and 'release' the locking Caps Lock key that will force the Caps Lock off, where the regular Caps Lock key would toggle.
Unfortunately, the Keyboard() function can't send keycodes higher than 119 and you need 130. You can add these functions to the Kayboard library to get support for all keycodes:
// pressRaw() adds the specified USB raw keycode to the persistent key
// report and sends the report.
size_t Keyboard_::pressRaw(uint8_t k)
uint8_t i;
// Add k to the key report only if it's not already present
// and if there is an empty slot.
if (_keyReport.keys[0] != k && _keyReport.keys[1] != k &&
_keyReport.keys[2] != k && _keyReport.keys[3] != k &&
_keyReport.keys[4] != k && _keyReport.keys[5] != k) {
for (i=0; i<6; i++) {
if (_keyReport.keys[i] == 0x00) {
_keyReport.keys[i] = k;
if (i == 6) {
setWriteError();
return 0;
sendReport(&_keyReport);
return 1;
// releaseRaw() takes the specified key out of the persistent key report and
// sends the report. This tells the OS the key is no longer pressed and that
// it shouldn't be repeated any more.
size_t Keyboard_::releaseRaw(uint8_t k)
uint8_t i;
// Test the key report to see if k is present. Clear it if it exists.
// Check all positions in case the key is present more than once (which it shouldn't be)
if (0 != k && _keyReport.keys[i] == k) {
_keyReport.keys[i] = 0x00;
return 1;
size_t Keyboard_::writeRaw(uint8_t c)
uint8_t p = pressRaw(c); // Keydown
releaseRaw(c); // Keyup
return p; // just return the result of press() since releaseRaw() almost always returns 1
You would add these functions to Keyboard.cpp and modify the Keyboard class in Keyboard.h to add:
