Keypad error
Hi there!
I´m having this error:
In file included from HelloKeypad.cpp:11:
D:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino/keypad.h:36:25: error: utility/Key.h: No such file or directory
I downloaded the keypad example and in the Verify process this error appears...
This is the code:
#include <Key.h>
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
void loop(){
char key = keypad.getKey();
if (key){
Serial.println(key);
Can anyone help?
Hello and welcome,
You must download the keypad library and install it in My documents/Arduino/libraries :slight_smile:
And next time use the code tags (the # button) around your code!
Hi again!
Another error:
HelloKeypad:17: error: 'Keypad' does not name a type
HelloKeypad.cpp: In function 'void loop()':
HelloKeypad:29: error: 'kpd' was not declared in this scope
In the code, "Keypad" is not colored in orange. Is this the problem?
Sorry if this is a stupid question... i started with arduino a few days ago...
I think there is everything you need on this page: Arduino Playground - HomePage
Try the examples provided with the library .zip, see how it compile without errors and only then, try to modify it as you want... Good luck :wink:
While you are at it, delete Arduino 1.0.1 and install 1.0. Do not go back to 1.0.1 until they fix the stupid problem where missing include files are OK.
