I got a keypad to switch relays when they use the correct code.
when the playeris entering the good code, it switch the relays.
When the player is entering the wrong code, he must try again.
but when I enter a wrong code, the correct code will not work anymore. It appears that he no longer recognized the correct code.
can anyone help me with?
#include <Keypad.h>
#include <Password.h>
Password password = Password( "4317" ); //password to unlock box, can be changed
const byte ROWS = 4; //4 rijen
const byte COLS = 3; //3 kolommen
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'},
byte rowPins[ROWS] = {10 ,9, 8, 7}; //connect to 4567
byte colPins[COLS] = {6, 5, 4}; //connect to 8910
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
Serial.write(254);
Serial.write(0x01);
delay(200);
pinMode(A0, OUTPUT); //buzzer1
pinMode(13, OUTPUT); //relay1
pinMode(11, OUTPUT); //relay2
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
keypad.getKey();
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
Serial.print("Enter: ");
Serial.println(eKey);
digitalWrite(A0, HIGH); //buzzer on
delay(10);
digitalWrite(A0, LOW); //buzzer off
Serial.write(254);
switch (eKey){
case '#': checkPassword(); delay(1); break;
case '*': password.reset(); delay(1); break;
default: password.append(eKey); delay(1);
void checkPassword(){
if (password.evaluate()){ //if password is right open box
Serial.println("Accepted");
Serial.write(254);delay(10);
digitalWrite(A0, HIGH);//turn BUZZER on
digitalWrite(13, HIGH);//turn RELAY on
digitalWrite(11, HIGH);//turn RELAY on
delay(2000); //wait 2 seconds
digitalWrite(A0, LOW);// turn BUZZER off
delay(3000); //wait 5 seconds
digitalWrite(13, LOW);//turn relay off
delay(3600000); //wait 60 minutes
}else{
Serial.println("Denied"); //if passwords wrong keep box locked
digitalWrite(A0, HIGH); //turn on
delay(300); //wait 0,3 seconds
digitalWrite(A0, LOW);//turn off
