keypad press displays in adafruit 2.8" tft touch screen
i want to display keypad press in tft .
but i cant get it in real time.
( as the result
in serial window i able to get numbers displayed when i pressed key for a several times :(.
as well as that key displayed in tft.)
how can i get it ?
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define   BLACK           0x0000
#define   BLUE            0x001F
#define   RED             0xF800
#define   GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#include "TFTLCD.h"
#include <Keypad.h>
const byte ROWS = 5;
const byte COLS = 4;
char buffer;
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
char keys[ROWS][COLS] =
  {'1','6','A','D'},
  {'2','7','B','E'},
  {'3','8','C','F'},
  {'4','9','X','Y'},
  {'5','0','Z','R'},
byte rowPins[ROWS] = {40,39,38,37,36}; //connect to row pinouts
byte colPins[COLS] = {32,33,34,35}; //connect to column pinouts
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(void)
  Serial.println("8 Bit LCD test!");
  tft.reset();
  tft.initDisplay();
void loop(void)
  char key = keypad.getKey();
  if (key != NO_KEY)
    Serial.print(key);
    buffer=key;
   testtext(BLACK);
// for TFT screen display letters
void testtext(uint16_t color)
  tft.fillScreen(CYAN);
  tft.setCursor(50, 20);
  tft.setTextColor(RED);
  tft.setTextSize(2);
  tft.println("HI TEXTS BELOW");
  tft.setCursor(80, 60);
  tft.setTextSize(3);
  tft.print(buffer);
I wonder why that might be.
thats for the screen display delay
yes within that delay keypad press are not taken.
but if i remove that line screen blinks often .
so how can i overcome this ?
By only updating the screen if something changes?
that will be effective.
only upgrade when keypad press only .
but how can i implement that ?
Well, I'd probably move the call to "testtext" inside the conditional, but you're the one with the hardware, so why not try it for yourself?
i tried my best to get the output as pressed numbers shown by column wise :relaxed:
but all i need is i want to display the pressed keys column wise ( like as ATM pin entering )
and save that sequence in a buffer.
:frowning:
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define   BLUE            0x001F
#define   RED             0xF800
#define CYAN            0x07FF
#include "TFTLCD.h"
#include <Keypad.h>
char buffer;
long lastUpdate = 0;
int x;
  {'1','6','A','D'},
  {'2','7','B','E'},
  {'3','8','C','F'},
  {'4','9','X','Y'},
  {'5','0','Z','R'},
void setup(void)
  tft.reset();
  tft.initDisplay();
void loop(void)
  if (key != NO_KEY)
    Serial.print(key);
    buffer=key;
  /*testtext(BLACK);
   delay(1000); */
  if((millis() - lastUpdate) > 100)  // has it been >1 second since the last update?
    testtext(BLACK);  // update display
    lastUpdate = millis();
  x=x+8;  // remember the time
//int y = (10*x);
  tft.setTextSize(2);
  tft.setCursor(x, 50);
  tft.setTextSize(3);
  tft.print(buffer);
One of us is over- or under-thinking this problem.
You know when the last update was, so why not only update the screen then?
i think its better to deliver an idea than
commenting those lines.
I couldn't agree more.
