I wrote a little library (lets say myLittleLib.h & myLittleLib.cpp, also config.h) where I use some defines, f.e.
#define DIM_TIME 500
within my config.h, which is then included in the myLittleLib.h.
This way, I can include and use the library (as long as the defines are stored in config.h within the library folder) using
#include "myLittleLib.h"
, all fine.
Now I´d like to define within the sketch, so I wrote a keywords.txt, also stored within the library/myLittleLib folder, just one line:
DIM_TIME LITERAL1
exactly one tab between DIM_TIME and LITERAL1.
Within the sketch, I now first define DIM_TIME, then I include the library:
#define DIM_TIME 500 #include "myLittleLib.h"
and comment it out within the config.h of the library.
Strangely, I get the error
"DIM_TIME was not declared in this scope".
Sadly, there is no useful google hit when searching for the LITERAL1-stuff. All is that is that it has to be set within the keywords.txt.
PieterP:
The keywords.txt file is used for syntax highlighting only, it doesn't change anything about the actual code.
Are you trying to use DIM_TIME in myLittleLib.cpp? You can't do that, because it's compiled separately from your sketch.
Pieter
Exactly, I use DIM_TIME within the myLittleLib.cpp.
I know there is definitely a way to use defines within the lib, f.e. the mySensors library works this way, there is "a lot" of stuff you define within the sketch. F.e. you can define MY_DEBUG and get the debug prints from the lib without using the define furthermore within the sketch..
Inso:
That is only possible if the defines are used just in the header files, not in the implementation files.
PieterP:
That would be absolutely enough for me, sadly if i set DIM_TIME only as a default value within the myLittleLib.h and use it nowhere else, I have the same problem: ... is not declared in this scope.
If you include the header file from the CPP file, you have the same problem, because including a file is just copy-and-pasting its contents into the current file.
You have to make the header file self-contained. You can make some functions inline if you have to, and you can split up the header file into two parts: one that uses the define, and one that's included from the CPP file.
Inso:
So do it the same way as the mySensors library:
There appears to be no "MySensors.cpp" so that could explain why the preprocessor defines aren't needed there.
johnwasser:
So do it the same way as the mySensors library: GitHub - mysensors/MySensors at master
After the answer of PieterP (thank you very much btw ), I remembered I was able to set MY_NODE_ID to a number within my sketch, which was then used by the MSGW. So I took a look for the define and where to find it within the library, and found three files (except the keywords.txt):
MyConfig.h:
* @def MY_PASSIVE_NODE
* @brief If enabled, the node operates fully autonomously, i.e. messages are sent without ACKing.
* @note All transport-related checks and safety-mechanisms are disabled.
* @note Requires that @ref MY_NODE_ID is set, @ref MY_PARENT_NODE_ID and
* @ref MY_PARENT_NODE_IS_STATIC are optional.
* @note Singing, registration, and OTA FW update are disabled.
//#define MY_PASSIVE_NODE
* @def MY_NODE_ID
* @brief Node id defaults to AUTO (tries to fetch id from controller).
#ifndef MY_NODE_ID
#define MY_NODE_ID (AUTO)
#endif
Inso:
It seems they are able to use it within the cpp-file without a problem..
No, with that code the .cpp file will ALWAYS see the #define(d) value of 'MY_NODE_ID' as 'AUTO' because that's how it's defined in the .h file. It doesn't matter how you #define 'MY_NODE_ID' in your .ino file, it will never, ever, ever, ever, ever be seen in the .cpp file. That's just the way it works.
gfvalvo:
I have used the library very frequently, and MY_NODE_ID was not used within my code anywhere. On the other hand, there is f.e.
MyTransport.cpp
if (MY_NODE_ID != AUTO) {
TRANSPORT_DEBUG(PSTR("TSM:INIT:STATID=%" PRIu8 "\n"),(uint8_t)MY_NODE_ID);
// Set static ID
_transportConfig.nodeId = (uint8_t)MY_NODE_ID;
// Save static ID to eeprom (for bootloader)
hwWriteConfig(EEPROM_NODE_ID_ADDRESS, (uint8_t)MY_NODE_ID);
which definitely used the ID set in the sketch to write f.e. the log file I then directly can see when debugging the gateway on the controller (RPI3).
You can also see on this post here: he only defines the NODE_ID before including and nowhere else, and the node id was set.
However, back to your solution. So if I need DIM_TIME in my library as a global variable, your way would be then writing a method setting a variable, and call this one from the .h - file method which can pass the define then, right?
Inso:
I don't know what that means and posting snippets is pointless. My statement stands: You can't change the definition of a macro as seen by a .cpp file by a using a #define directive in your .ino file. Period. End of story. Move on.
I don't know what any of that means either. DIM_TIME is not a variable (global or otherwise). It's a pre-processor macro. What about the example I posted doesn't make sense?
gfvalvo:
On the first point: Its definitely possible within the other library. I have postet all code snippets which mention the MY_NODE_ID, and there is no re-setting or something else anywhere within the library. They definitely use the pre-processor-macro directly within a cpp-file, I just cannot find out how they pass it over.
On the second: as the solution I tried to explain is very ugly and would lead to awful code (my lib contains a few classes and dozens of methods, also dozens of #defines and so on..^^) I will rewrite it using templates or setter methods instead. Or maybe I post the question over in the mySensors-forum and find out how they did it.
Thank you (and all others^^) very much for the great help and explanations. If I get the information how they did it, I will definitely post it here .
Inso:
Here's how. From MySensors.h:
#include "core/MyGatewayTransport.cpp"
IMO, a REALLY bad thing to do. If MySensors.h get's #include(d) into one or more .cpp files in addition to the .ino file, there will be multiple definitions of all the functions contained within and you'll get a mass of linker errors.
