Kind of Fail safe
I want to add a fail safe sort of thing of initial power up.
At the moment I'm only detecting 2 buttons but will need add another 2. So if a button is pressed on power up it stops it from going to the main loop and jumps to error loop where I flash an LED.
I'm only debugging it and just print data to serial port to show that the loop is working.
This is working but was wondering if it could be improved or more of an elegant way of doing it ?
#define  FWD_input  3 //forward signal from joystick
#define BCK_input 4 //reverse signal from joystick
#define Error_led A3 //Error LED on power up
int ledState = LOW;
unsigned long previousMillis = 0;        // will store last time LED was updated
// constants won't change:
const long interval = 250;
  pinMode(Error_led, OUTPUT);
  digitalWrite(Error_led, LOW);
  pinMode(FWD_input, INPUT_PULLUP);
  pinMode(BCK_input, INPUT_PULLUP);
  Serial.print("TEST POWER UP");
  //Detect if any buttons are pressed on start up fail saafe if so jump to error loop
  while ((digitalRead(FWD_input) == LOW) || (digitalRead(BCK_input) == LOW)) {
    Error();
  Serial.println("NO ERROR"); // Just print this so you can see loop working
void Error() {
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(Error_led, ledState);
A neater way of changing the state of an LED if you don't need the state as a variable is
digitalWrite(ledPin, !digitalRead(ledPin));
Thanks that looks a lot neater and less code, I never thought about doing it that way
