Make changes in FreertosConfig.h file.
#define INCLUDE_xTimerPendFunctionCall 1
#define configTIMER_TASK_PRIORITY 2
#define configTIMER_TASK_STACK_DEPTH (configMINIMAL_STACK_SIZE+(unsigned short)64)
Note: The timer stack size varies according to its callback function
for Low Power usage #define configUSE_TICKLESS_IDLE 1
Example:
#include <Arduino_FreeRTOS.h>
#include <timers.h>
#include <avr/sleep.h>
#include <util/atomic.h>
#include <stdlib.h>
#define ONESECONDDELAY 1000/portTICK_PERIOD_MS
#define HALFSECONDDELAY 500/portTICK_PERIOD_MS
#define TIMERBLOCKTIME UINT32_C(0xffff)
#define TIMERAUTORELOAD_ON 1
const byte interruptPin = 2;
void Application_init(void);
TimerHandle_t timer1;
TimerHandle_t timer2;
static void appDeferredISRCallback(void *interruptDataQueuePtr, uint32_t interruptData)
(void) interruptDataQueuePtr;
(void) interruptData;
Serial.println("appDeferredISRCallback received\n");
static void realTimeISRCallback(void)
signed portBASE_TYPE xHigherPriorityTaskWoken=pdFALSE;
if(xTimerPendFunctionCallFromISR(appDeferredISRCallback, NULL, 0, &xHigherPriorityTaskWoken)==pdPASS)
taskYIELD();
static void timer1_callback(void *pvParameters)
(void) pvParameters;
Serial.println(rand());
static void timer2_callback(void *pvParameters)
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin),realTimeISRCallback, CHANGE);
timer1 = xTimerCreate("timer1", ONESECONDDELAY, TIMERAUTORELOAD_ON, NULL, timer1_callback);
timer2 = xTimerCreate("timer2", HALFSECONDDELAY, TIMERAUTORELOAD_ON, NULL, timer2_callback);
xTimerStart(timer1, TIMERBLOCKTIME);
xTimerStart(timer2, TIMERBLOCKTIME);
// initialize serial communication at 9600 bits per second:
Application_init();
vTaskStartScheduler();
void vApplicationStackOverflowHook();
// Remember that loop() is simply the freeRTOS idle task.
// It is only something to do, when there's nothing else to do.
set_sleep_mode( SLEEP_MODE_IDLE );
ATOMIC_BLOCK(ATOMIC_RESTORESTATE)
sleep_enable();
#if defined(BODS) && defined(BODSE) // Only if there is support to disable the brown-out detection.
sleep_bod_disable();
#endif
sleep_cpu(); // good night.
// Ugh. I've been woken up. Better disable sleep mode.
sleep_disable();
My sincere thanks to Felipu
