Hi All,
I am having an issue with my Arduino UNO WiFi Rev2 board whereby the 'L' LED is constantly blinking when I upload my code (sample below). The code was working fine, until I added in a couple of extra feeds to my Adafruit IO Dashboard. It seems every time I use more than 5 feeds within the code, the 'L' LED begins to blink and nothing happens.
Is there any obvious errors within my code, or any advice that anyone could share as I am going to need possibly up to 10 feeds in total.
Many thanks,
George
// Defines
#define AIO_USERNAME "*******"
#define AIO_KEY "*******"
#define AIO_DMOSA_FEED "dmosatransducer"
#define AIO_TARE_FEED "tare"
#define AIO_CONFIRM_FEED "confirm"
#define AIO_DATASTREAM_FEED "datafeed"
#define AIO_DMOSAHEALTH_FEED "dmosa-healthy"
#define AIO_PTOSLHEALTH_FEED "ptosl-healthy"
#define WIFI_SSID "*******"
#define WIFI_PASS "*******"
#define USE_AIRLIFT // required for Arduino Uno WiFi R2 board compatability
// Libraries
#include <AdafruitIO_WiFi.h>
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFiUdp.h>
#include <TimeLib.h>
// Constructors
AdafruitIO_WiFi aio(AIO_USERNAME, AIO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS, SPIWIFI_ACK, SPIWIFI_RESET, NINA_GPIO0, &SPI);
AdafruitIO_Feed *DMOSAHealth = aio.feed(AIO_DMOSAHEALTH_FEED);
AdafruitIO_Feed *PTOSLHealth = aio.feed(AIO_PTOSLHEALTH_FEED);
AdafruitIO_Feed *DMOSAFeed = aio.feed(AIO_DMOSA_FEED);
AdafruitIO_Feed *TareFeed = aio.feed(AIO_TARE_FEED);
AdafruitIO_Feed *ConfirmFeed = aio.feed(AIO_CONFIRM_FEED);
AdafruitIO_Feed *DataStreamFeed = aio.feed(AIO_DATASTREAM_FEED);
int SENSORVALUE = A0;
int P0 = 0;
float pressure_pascal;
float pressure_bar;
float pressure_psi;
float Brake_Step_1;
float Brake_Step_2;
float Brake_Step_3;
float Brake_Step_E;
float EmergencyLow;
float EmergencyHigh;
float Voltage;
float error = 0;
bool value = 0;
bool value_confirm = 0;
int status = WL_IDLE_STATUS;
char ssid[] = WIFI_SSID; // your network SSID (name)
char pass[] = WIFI_PASS; // your network password (use for WPA)
unsigned int localPort = 2390; // local port to listen for UDP packets
unsigned long offset_days = 3; // 3 days
unsigned long t_unix_date1, t_unix_date2, unixdt;
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
IPAddress timeServer(79, 135, 97, 79); // ntp.exnet.com NTP server
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
pinMode(SENSORVALUE, INPUT);
while(!Serial); // wait for serial connection
// Adafruit IO connection and configuration
Serial.print("Connecting to Adafruit IO");
aio.connect(); // connect to Adafruit IO service
while(aio.status() < AIO_CONNECTED) {
Serial.print(".");
delay(1000); // wait 1 second between checks
Serial.println(aio.statusText()); // print AIO connection status
DMOSAHealth = 1;
while(PTOSLHealth = 0); //Wait for PTOSL Healthy Signal
Serial.println("\nStarting connection to Time server...");
Udp.begin(localPort);
// Set up message handler that calls function when messages are received
TareFeed->onMessage(TareMessageHandler);
TareFeed = 0; // set initial value as 0 (DO I NEED THIS ANYMORE??)
ConfirmFeed->onMessage(ConfirmMessageHandler);
Date_Time_NTP(); // Set up connection to Date / Time server
aio.run();
PressureCalc();
DataStreamFeed->save("Please Release the Brakes");
Serial.println("Please release the Brakes");
delay(50);
BrakeRelease();
DataStreamFeed->save("Ready to Begin?");
Serial.println("Ready to Begin?");
while(value_confirm != 1){aio.run();PressureCalc();} // Wait for the Confirm button to be pressed, keep pressure calculations updated
value_confirm = 0; // set value back to 0 after Confirm has been pressed
BrakeStep1();
BrakeStep2();
BrakeStep3();
BrakeStepE();
BrakeTimings();
// Handles Tare feed message received from AIO
void TareMessageHandler(AdafruitIO_Data *data) {
value = data; // capture feed value from AIO
Serial.print("Tare feed received -> "); Serial.println(value);
if (value = 1) {
float pressure_bar_error = (((3*(Voltage-0.4937))*1000000.0)/10e5);
error = 0 + pressure_bar_error;}
// Handles Confirm feed message received from AIO
void ConfirmMessageHandler(AdafruitIO_Data *confirm) {
value_confirm = confirm; // capture feed value from AIO
Serial.print("Confirm feed received -> "); Serial.println(value_confirm);
