L298 motor driver spinning motor in only one direction
Hi, I working on one of my project using ESP32 and L298 motor driver. L298 was working fine till yesterday but today it is spinning in only one way with ESP32 as a main board. I'm powering L298 driver with 12v, driver ground is grounded with ESP32 ground.
int motor1Pin1 = 13;
int motor1Pin2 = 14;
  // sets the pins as outputs:
  pinMode(motor1Pin1, OUTPUT);
  pinMode(motor1Pin2, OUTPUT);
  // testing
  Serial.print("Testing DC Motor...");
  // Move the DC motor forward at maximum speed
  Serial.println("Moving Forward");
  digitalWrite(motor1Pin1, LOW);
  digitalWrite(motor1Pin2, HIGH);
  delay(2000);
  // Stop the DC motor
  Serial.println("Motor stopped");
  digitalWrite(motor1Pin2, LOW);
  // Move DC motor backwards at maximum speed
  Serial.println("Moving Backwards");
  digitalWrite(motor1Pin1, HIGH);
  delay(2000);
If you have a 5V Arduino, see if the driver and sketch works with it.
Can you share a picture?
If you use a breadboard, a loose contact might be your problem.
