I'm using L298n motor driver nhi my project. I accidentally attached 6v to 5v pin rather than 12v pin and now when I give 6v to 12v pin, the board gets light up but motor connected to driver does not move.
So, does I fry the driver?
6V is not enough to drive a motor with this chip. Try 12V and see what happens.
That old chip loses about 2V by itself. So your 5V supply leaves 3V for the motor.
Get a better motor driver such as the TB6612FNG or DRV883x. Similar power switching abilities minus the huge losses (and no heat sink).
Sdongre:
According to the datasheet you're ok; it can take 7V.
wvmarle:
Closer to 5V lost in fact, if there's a bit more current. Might be that at start up stall current, there's basically no voltitude left.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What are the motors you are trying to drive?
What is you motor power supply.
Thanks.. Tom.... ![]()
thnx for all replies. the problem is solved now
Sdongre:
What was the solution, to help other enquirers it would be good if you posted what you did to fix your problem.
Thanks.. Tom.. ![]()
