LA66 dragino shield with arduino uno AT Commands does not seem to work
I have two arduino uno both connected to a dragino LA66 shield and I tried to send and receive a simple "hello world " message from one to another by starting by this tutorials but I do not understand how it works (where the message can be fetched ?)?
Do you have a simple example sending and receiving a message from one to another la66 shield ?
Loading this code on both the arduino uno and executing
AT+SEND=12:hello I do not see the message on the other one.
This topic has been addressed in this subject but no answers has been given.
Any suggestions is welcome.
Thanks in advance
have you connected the LA66 to the UNO using pins 10 and 11? e.g.
SoftwareSerial LA66_serial_port(10, 11);    // Arduino RX, TX ,
looking at LA66 AT commands have you tried commands such as
AT+CFG
which displays configurations
Thank you for your answer.
Yes I followed this code given by the documentation.
The command AT+CFG gives a list of configurations:
Now I would want to send a « hello world » message from one device and receive it from the other one.
if AT+CFG works OK on both devices have a look at Instruction for LA66 Peer to Peer firmware
e.g. to send a message
 AT+SEND=1,hello world,0,3
and at the receiver
AT+RECV=1
When I execute this AT command I got AT_PARAM_ERROR:
And When I execute AT+RECV=1 I get the same error:
I tried to reset the MCU with ATZ and Reset Parameters to Factory Default with AT+FDR but it does not change anything.
Following this I tried :
AT+SEND=12:helloworld and AT+RECV=? I don't get an error but nothing happens when I sent the message.
