Hi! Still trying to build an Arduino Uno arm. Came across a different issue now. A Servo - that controls the base axis of the arm - is doing well when it's controlling just the arm and another servo, that isn't connected to the Arduino. The problem arises when I try to connect it, so it can act as another joint.
(Note: Both servos are controlled using a joystick.)
The Axis-Arm servo starts to lag, move inconsistently and sometimes even stops for a while. For some reason, the second servo moves flawlessly. Just to clear up any questions - no, it's not because of the weight, the Axis-Arm servo moves just right when the second is not connected, I even tried to attach some extra weight to the arm, and it's doing fine without concern.
Reference picture:
Code:
#include <AccelStepper.h>
#include <Servo.h>
#define HALFSTEP 8
#define STEPPER_DEADBAND 75
#define STEPPER_MAX_ROTATION 1536
#define SERVO_MIN_PULSE_WIDTH 544
#define SERVO_MAX_PULSE_WIDTH 2400
#define SERVO_AXIS_MAX_ANGLE 30
#define POTENTIOMETER_PIN A0
#define SERVO_AXIS_PIN 3
#define SERVO_ARM_PIN 5
#define JOYSTICK_AXIS_X_PIN A4
#define JOYSTICK_AXIS_Y_PIN A5
int potentiometerValue = 0;
int previousPotentiometerValue = 0;
int stepperMoveToPosition = 0;
const int servoAxisBoundaries = (SERVO_MAX_PULSE_WIDTH + SERVO_MIN_PULSE_WIDTH) / (180 / SERVO_AXIS_MAX_ANGLE);
int servoAxisPosition = 1500;
int servoArmPosition = 1500;
int joystickXValue = 0;
int joystickYValue = 0;
AccelStepper stepper(HALFSTEP, 8, 10, 9, 11);
Servo servoAxis;
Servo servoArm;
pinMode(POTENTIOMETER_PIN, INPUT);
pinMode(JOYSTICK_AXIS_X_PIN, INPUT);
pinMode(JOYSTICK_AXIS_Y_PIN, INPUT);
stepper.setMaxSpeed(1000.0);
stepper.setAcceleration(100.0);
stepper.setSpeed(500);
servoAxis.attach(SERVO_AXIS_PIN, SERVO_MIN_PULSE_WIDTH, SERVO_MAX_PULSE_WIDTH);
servoArm.attach(SERVO_ARM_PIN, SERVO_MIN_PULSE_WIDTH, SERVO_MAX_PULSE_WIDTH);
servoAxis.writeMicroseconds(servoAxisPosition);
servoArm.writeMicroseconds(servoArmPosition);
potentiometerValue = constrain(analogRead(POTENTIOMETER_PIN), 100, 900);
joystickXValue = constrain(analogRead(JOYSTICK_AXIS_X_PIN), 100, 900);
joystickYValue = constrain(analogRead(JOYSTICK_AXIS_Y_PIN), 100, 900);
if (abs(previousPotentiometerValue - potentiometerValue) > STEPPER_DEADBAND) {
previousPotentiometerValue = potentiometerValue;
stepperMoveToPosition = map(potentiometerValue, 100, 900, -STEPPER_MAX_ROTATION , STEPPER_MAX_ROTATION);
stepper.moveTo(stepperMoveToPosition);
if (joystickYValue < 525 && servoAxisPosition > SERVO_MIN_PULSE_WIDTH + servoAxisBoundaries) {
servoAxisPosition -= (abs(500 - joystickYValue)) / 125;
if (joystickYValue > 475 && servoAxisPosition < SERVO_MAX_PULSE_WIDTH - servoAxisBoundaries) {
servoAxisPosition += (abs(500 - joystickYValue)) / 125;
if (joystickXValue < 525) {
servoArmPosition -= (abs(500 - joystickXValue)) / 125;
if (joystickXValue > 475) {
servoArmPosition += (abs(500 - joystickXValue)) / 125;
stepper.run();
I've already tried implementing timers, but I doesn't do anything, because the idea is to try and move every motor, every time the loop function repeats. I'm concerned that Arduino just can't keep up with updating the position of the motors. Does anyone know if creating a separate C++ file and rewriting the "servo-stepper" part with constructors would do anything here? Any other solutions? I would be grateful.
P.S. I can post the wiring and more pictures if necessary.
