LAN8720 Ethernet module?
hello, I was wondering if anyone had uses this LAN8720 ethernet module here ? And If so what library should i se to program this module. I only found it for Esp32. Nothing for the arduino boards.
Joseph
You cant use it . Its an PHY-Module designed dir Controllers, equiped with RMII-Interface, like an ESP32.
In other Case you schould use an w5x00-Interface.
Greetz Nano
Hello, Thank you. I was trying to find a Alternative to wiznet modules or ENC28J60 that doesn't take spi.
Edit: i was looking for a serial to ethernet module that works on arduino.
Joseph
