i need help to write a code for landing gear with arduino ide and work for dcs bios
Welcome
Your topic does not indicate a problem with the IDE and hence has been moved to a more suitable location on the forum.
and where will it move? what subject?
What might that be?
to work for the dcs bios is a program
Good to know, thanks!
to tell you more specifically i have the msc and i want a code for the landing system for this purpose but i use the dsc bios to make it work
I don't know if I'm helping you as I say.... I'm new and I don't know it well
Look underneath the topic title.
that's the thread we're on now right?
It's the thread that you started. The only thing that changed is that originally it was under "using arduino / ide 1.x" and now it's under "using arduino / project guidance".
Αααα οκ....
can this library help?
I'll try this library to see... and I'll get back to you if it works or not
I don't know if I have the right code
Help code for landing gear??
Are you expecting someone to code for you?
