Large (64^2) Array Issue
Hi all,
I must be overlooking something super simple but my debugging efforts haven't gotten me as far as solving this issue, and neither has my googling.
I have a 64 x 64 array that I'm using to store ints. The purpose of this array is that I'll call through each of its elements to draw to a 64 x 64 RGB LED matrix, and the ints within the array represent a colour (I am drawing pictures on the RGB LED matrix essentially for my GF).
However, when I try and run a test serial print code to test the array, if I call the array at any point in the code nothing happens in the serial monitor. I also created a test 10 x 10 array to make sure my serial monitor etc. is working, and it is.
Test Code (just calling a 10 x 10 array):
uint8_t test_array[10][10] = {
  {0,0,0,0,0,0,0,0,0,0},
  {1,1,1,1,1,1,1,1,1,1},
  {2,2,2,2,2,2,2,2,2,2},
  {3,3,3,3,3,3,3,3,3,3},
  {4,4,4,4,4,4,4,4,4,4},
  {5,5,5,5,5,5,5,5,5,5},
  {6,6,6,6,6,6,6,6,6,6},
  {7,7,7,7,7,7,7,7,7,7},
  {8,8,8,8,8,8,8,8,8,8},
  {9,9,9,9,9,9,9,9,9,9}};
  test_test();
void loop() {}
void test_test()
  for(uint8_t ii = 0; ii < 10; ii++){
    for(uint8_t jj = 0; jj < 10; jj++){
      Serial.print(test_array[ii][jj]); Serial.print(","); //test 10 x 10 array
and the print out is as expected, shown below:
0,0,0,0,0,0,0,0,0,0,
1,1,1,1,1,1,1,1,1,1,
2,2,2,2,2,2,2,2,2,2,
3,3,3,3,3,3,3,3,3,3,
4,4,4,4,4,4,4,4,4,4,
5,5,5,5,5,5,5,5,5,5,
6,6,6,6,6,6,6,6,6,6,
7,7,7,7,7,7,7,7,7,7,
8,8,8,8,8,8,8,8,8,8,
9,9,9,9,9,9,9,9,9,9,
Now if I call my pig_array as well(the 64 x 64), not only is the pig_array not printed in the serial monitor, the test array doesn't get printed either. Absolutely nothing is printed in the serial monitor - it's as if just calling the pig_array makes the code break? I thought I would atleast get 1 entry of the test array printed with the below code, since the test array is called before the pig array:
void test_test()
      Serial.print(pig_array[ii][jj]); Serial.print(",");   // 64 x 64 array
FYI, I am also aware that if the above did print, it would be a jumbled mess in the serial monitor printing entries of each array of each other... I started with the 64 array and was just debugging with the 10 x 10 array and was lazy.
Does anyone have any ideas? I'll also show the 64 x 64 array at the bottom of the post since its quite big.
Thanks for your help! I appreciate it.
uint8_t pig_array[64][64] = {
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,0,2,1,1,1,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,0,0,0,2,1,1,1,1,1,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,0,2,0,0,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,2,1,1,0,1,1,1,0,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,1,1,0,1,1,1,1,2,2,2,0,1,0,1,1,1,0,0,2,1,0,0,2,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,2,1,1,1,1,1,1,2,1,1,1,1,1,1,2,1,1,1,1,1,1,1,2,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,2,1,1,1,1,1,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,2,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,2,1,1,1,1,1,2,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,1,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,2,1,1,1,1,2,2,1,1,1,1,1,1,1,1,1,1,2,2,1,1,1,1,1,2,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
  {0,0,0,0,1,1,2,2,1,1,1,1,1,1,1,1,1,1,1,1,1,1,2,1,1,1,1,1,0,1,1,1,1,1,1,1,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,0,0},
  {0,0,0,0,2,0,0,0,2,2,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,2,2,2,0,0,0,0,0,2,2,0,0,0,0,0,0,0,0,0,0,2,1,1,2,0},
  {0,0,0,0,0,0,0,2,0,3,2,1,1,1,1,1,1,1,0,2,1,1,1,1,1,1,1,1,1,0,1,1,1,1,1,2,2,0,1,1,1,1,1,1,1,1,1,1,1,1,1,2,0,0,0,0,0,0,2,1,2,2,1,0},
  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}};
What board are you trying to compile this for?
Won't fit in UNO...
64x64=4096
As it is a sparse matrix, you might use vectorized storage. Per pixel it will take more memory, but you will not need to store the zeros.
Arduino Mega
What's the maximum I can have for a MEGA?
I've never done vectorised storage before - I'll look into it thank you!
Admittedly I knew in the back of my head that there will be many better more efficient ways to do this haha...
It prints for me when loaded into a Mega.
Mega has 8 kB, so should fit.
I dont have it plugged in atm but these are my board settings
Not sure if this is any use.. admittedly it does look quite large.
I'm not familar with any of this FYI
A 64x64 array of int on Mega will require 64x64x2=8192 bytes of RAM (dynamic) memory.
A 64x64 RGB array, if using NeoPixel or FastLED libraries, will require 64x64x3x2=24567 bytes of RAM memory.
How much RAM memory does Mega have?
8K of RAM. @hamishgreen's sketch uses 4386 bytes (assuming I've patched it together correctly).
My question was directed at @hamishgreen. We all know the answer already.
Of RAM? Or Flash?
Sorry I tried to help out.
I begun by following the guide here for 64 x 64 LED RGB matrix for arduino MEGA:
I'll be honest in that I dont know a lot about memory RAM vs flash etc. I'll have to read up on it.
In the test sketch there is no neopixel library or something like that.
Also, the 'colors' are coded as uint8_t.
So, it should fit.
The demo software use its own buffer for outputting to the matrix, you must not create another one. Arduino Mega hasn't enough memory to work with dual buffer.
I recommend you to change the board to ESP32 or RaspberryPico, that used in the tutorial too.
No, I'm sorry. I should have explicitly directed my question at @hamishgreen.
You're right, I missed that.
I saw this and assumed 2 bytes for each array element.
OP said
64x64 entries in the array is 4 096 entries but each entry (an int) is 2 bytes on the MEGA…. So 8KB for the array ➜ too large
Going with one byte or less per pixel (RGB 323 or indexed colors for example) would fit
