Ok, so this is a pretty good start and thanks for posting your full code correctly. Let's make a few changes to start developing habits that will make this a little easier for you.
Before you consider the revisions, note that the IR stuff has been left out for now. One step at a time. I think you want to use an IR remote as a blaster to take the place of the fire button? Is that right? Also, i didn't see the reset button but let's leave that for now, too.
Final note: I didn't read any other code suggestions here before posting. My suggestions are standalone, probably not the best among the suggestions but without further ado:
// #include <EEPROM.h> get rid of this for now. One stage at a time in game building
// let's do something fun since you seem to be using Uno R4
#include "Arduino_LED_Matrix.h" // Include the LED_Matrix library, more here: https://docs.arduino.cc/tutorials/uno-r4-wifi/led-matrix/#sequencedone
#include <IRremote.hpp>
ArduinoLEDMatrix matrix; // Create an instance of the ArduinoLEDMatrix class
// const int for things like pin assignments that will never change
const int irTx = 2; // naming conventions help with longer code, good habit to get into
const int irRx = 3;
const int fireButton = 4;
const int reloadButton = 5;
const int resetButton = 6;
const int rLed = 7;
const int gLed = 8;
// the declarations below are ok.
int addr = 0;
int fire = 0;
int reset = 0;
int ammo = 30;
int hp = 0;
int pews = 0;
int reload = 0;
// lots of white space lines don't help; I deleted some
Serial.begin(115200); // 9600? Let's go faster, it's 2025
Serial.println("IR blaster game v1.0"); // so you always know what's loaded on the board
matrix.begin(); // Initialize the LED matrix
pinMode(irTx, OUTPUT); //transmitter
pinMode(irRx, INPUT); //receiver
pinMode(fireButton, INPUT_PULLUP); //no need for external resistors with pushbuttons
pinMode(reloadButton, INPUT_PULLUP);
pinMode(resetButton, INPUT_PULLUP);
pinMode(gLed, OUTPUT); //green LED
pinMode(rLed, OUTPUT); //red LED
// a for loop is a great way to repeat something, say 5 times or however much you like
for (int i = 0; i < 5; i++) {
digitalWrite(gLed, HIGH); // let's toggle these to know they work
digitalWrite(rLed, HIGH);
delay(250);
digitalWrite(gLed, LOW);
digitalWrite(rLed, LOW);
delay(250);
} // end of for loop that toggles LEDs
digitalWrite(gLed, LOW); // let's init these to off
// if () << what was the idea here? It's between setup and loop, so...? Delete it
// you need some sort of debouncing of buttons and you'll see why in Serial
fire = digitalRead(fireButton);
reload = digitalRead(reloadButton);
// remember INPUT_PULLUP below? The catch is your logic must be reversed so keep that in mind
if (reload == LOW) { // was HIGH, changed to LOW because INPUT_PULLUP
// digitalWrite(7, HIGH); -- which was this one again?
digitalWrite(rLed, HIGH); // Oh yeah, red - isn't that easier to follow? Let's get the LED lit right away
matrix.clear();
matrix.loadFrame(LEDMATRIX_EMOJI_HAPPY);
ammo = 30;
if (ammo >= 30) // this will keep ammo always at 30, I think you mean > so magazine can't be more
ammo = 30;
Serial.println("reloaded");
delay(100);
digitalWrite(rLed, LOW); // and turn it back off
if (fire == LOW) {
matrix.loadFrame(LEDMATRIX_CHIP);
if (ammo > 0) {
pews++;
ammo--;
} else if (ammo <= 0) {
matrix.loadFrame(LEDMATRIX_DANGER);
ammo = 0;
Serial.print("pew, ");
Serial.print(pews);
Serial.print(" ammo, ");
Serial.println(ammo);
delay(50);
matrix.clear();
} //loop end
