I am working on a project trying to put together a laser speed trap, but with a deadline coming up and one of my 2 photo-resistors broken, I had to resort to making a laser pathway using a mirror in order to simulate 2 points of breaking the line of sight. For the life of me, I can't seem to get the code worked out, as the blue LED is constantly on, the red never turns on, neither alternate like I specified, and the calculations involving millis() provide really strange answers, all of which are a composition of ones and zeros, usually around 10 or so of them. I attempted to put in some place markers to get some output on the individual times too, but they also turn out just as weird. I've spent the last 2 days stumped. I haven't even attached the LCD display yet because the basis for its output isn't correct yet. Here is the entire code:
#include <LiquidCrystal.h>
#include <SoftwareSerial.h>
int red = 8, blue = 12, green = 13, yellow = 7, photo = 0, toggle = 4;
const double distance = 6, limit = 12, threshold = 270;
bool reset;
unsigned long time1 = 0, time2 = 0, timetotal;
float velocity;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
pinMode(red, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(green, OUTPUT);
pinMode(yellow, OUTPUT);
pinMode(photo, INPUT);
pinMode(toggle, INPUT);
lcd.begin(16, 2);
velocity = 0;
time1 = 0;
time2 = 0;
timetotal = 0;
digitalWrite(red, LOW);
digitalWrite(blue, LOW);
digitalWrite(green, LOW);
digitalWrite(yellow, LOW);
reset = false;
lcd.print(0, 2);
while ( (analogRead(photo) <= threshold) && (reset == false) )
digitalWrite(yellow, HIGH);
Serial.println("step1");
while ( (digitalRead(yellow) == HIGH) && (digitalRead(toggle) == HIGH) )
Serial.println("step2");
while ( (analogRead(photo) > threshold) && (reset == false) )
Serial.println("step3");
if (time1 == 0)
time1 = millis();
Serial.println("step4");
if (analogRead(photo) > threshold)
Serial.println("step5");
time2 = millis();
timetotal = time2 - time1;
velocity = distance/timetotal;
lcd.print(velocity, 2);
Serial.println(time1, 2);
Serial.println(time2, 2);
Serial.println(velocity, 2);
if (velocity > limit)
while (digitalRead(toggle) == HIGH)
digitalWrite(red, HIGH);
delay(50);
digitalWrite(blue, HIGH);
delay(50);
digitalWrite(green, HIGH);
reset = true;
I tested to see if millis() itself was off by using a very basic test code to get millis(), delay for 1 second, then get millis() again and subtract for elapsed time, which worked fine, always 999 or 1000 milliseconds, on the dot. The next step I took was removing all the fluff and testing a circuit and code that only has 1 LED indicator to show the laser is properly positioned onto it. The rest is just pure stages for if statements, yet it still pulls random assortments of ones and zeros for the 2 time values, and the speed calculation comes out just as weird. The code for that circuit is here:
int yellow = 7, photo = 0, state = 0;
const double distance = 6, threshold = 270;
unsigned long time1 = 0, time2 = 0;
float timetotal, velocity;
if (analogRead(photo) <= threshold)
if (state == 0)
time1 = millis();
state = 1;
else if (state == 1)
state = 2;
else if (state == 2)
time2 = millis();
Serial.println(timetotal, 2);
velocity = (distance/timetotal)/1000;
state = 0;
Any help would be greatly appreciated, at the very least on the front of getting the whole millis() situation sorted out, as that is supposed to be the main feature. The laser is fed by a pure power source, and not a pin, thus why it's not listed in the code.
