system
1
Anyone know where i can find an up to date Command list for this Serial Backpack ?
The datasheet on Sparkfun is incorrect.
I cannot link the datasheet as this is my first post but there was another inquiry for this and no help :S
Any help would be appreciated...
Regards
Togs
system
2
Have you tried emailing the author of this tutorial? Or Sparkfun support in general?
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=120
system
3
Yip...
try click on on the link to the code and :
We're Sorry!
The page you have requested cannot be found!
Go Back
This appears to be the correct link to the source code...
http://www.sparkfun.com/Code/Graphic%20LCD%20Backpack%20-%20ATMega168.zip
In the worst case, you can get to it from here...
system
5
;D
Ok, for all the noobs like myself out there... to place cursor :
Serial.print(0x7C, BYTE); // command follow
Serial.print(0x19, BYTE); // X-axis follows
Serial.print(0x00 BYTE); // 00 is X-axis in HEX
Serial.print(0x18, BYTE); // Y-axis follows
Serial.print(0x00, BYTE); // 00 is Y-axis in HEX
this seem to be right and all the other info on the Datasheet.
Now... :-/ anyone knows what the command is for setting the Contrast ? (Brightness/Backlight is 0x7C 0x02)
Again any help would be appreciated.
Thanks
Togs
