I connected to my board lcd screen and a rfid scanner(MFRC522) I want that when i scan the tag that registered in the code on the lcd there will be text "Welcome" and then clear it but when i do it its only adding a weird symbol after "Welcome" and the same on unregistered tags...
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn't show the posting toolbar then you can just manually add the code tags:
[code]
[color=blue]// your code is here[/color]
[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you're using the Arduino Web Editor you will not have access to this useful tool but it's still unacceptable to post poorly formatted code. I recommend you to use the standard IDE instead.
Please remove unnecessary blank lines from your code before posting to the forum. One or two to separate code into logical sections is fine but large spaces for no reason or random blank lines just make for more scrolling when we're trying to read your code.
#include <RFID.h>
#include <LiquidCrystal.h>
#include <SPI.h>
#include <RFID.h>
#define SS_PIN 10
#define RST_PIN 9
RFID rfid(SS_PIN, RST_PIN);
const int rs = 1, en = 8, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int led1 = 7;
int led2 = 6;
int power = 8;
int serNum[5];
int cards[][5] = {
{ 104, 102, 176, 121, 199
bool access = false;
lcd.begin(16, 2);
SPI.begin();
rfid.init();
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
if (rfid.isCard()) {
if (rfid.readCardSerial()) {
Serial.print(rfid.serNum[0]);
Serial.print(" ");
Serial.print(rfid.serNum[1]);
Serial.print(" ");
Serial.print(rfid.serNum[2]);
Serial.print(" ");
Serial.print(rfid.serNum[3]);
Serial.print(" ");
Serial.print(rfid.serNum[4]);
Serial.println("");
for (int x = 0; x < sizeof(cards); x++) {
for (int i = 0; i < sizeof(rfid.serNum); i++ ) {
if (rfid.serNum[i] != cards[x][i]) {
access = false;
access = true;
if (access) break;
if (access) {
digitalWrite(led1, HIGH);
lcd.print("Welcome");
delay(2500);
lcd.clear();
digitalWrite(led2, HIGH);
lcd.print("Tag not registered");
delay(2500);
lcd.clear();
rfid.halt();
