LCD custom characters?
How do you make custom characters for HD44780-controlled LCD displays? I am using the default Liquid Crystal Library that comes with the software. Sample code would be appreciated. :slight_smile:
This is basically what i want to achieve:
the one in the video was make with a PIC microcontroller and I'm wondering how to do it with an arduino
There is some code to create custom characters with LiquidCrystal at the end of this thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1233339330/8
thanks for that link. I modified the code for my 16x2 and ran the code and it worked fine. But when I read the code I found it really confusing :-[ I can see that it creates some sort of array which stores the custom chracters but other than that, i get lost :-/ If it isn't asking for too much, can you or someone else write a simple hello-word-type example that maybe uses one or two custom characters
here are some links that may help you understand how the custom characters are handled by the LCD:
http://www.rentron.com/Myke2.htm
http://deanandara.com/robots/ApuLcd.html
Thanks, the last link explained alot
