LCD Menu with Switch/Case
hi all,
I try to make a simple menu on the LCD display, with switch / case
menu should be in the form:
menu1
menu2 -- submenu21 -- submenu22
menu3
here is the piece of code that does not work
I used button.h
the problem is with the 2nd "if", there in no action when I press button3
 void state() {
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 0);
   // Print a message to the LCD.
  //lcd.print("Voltage:");// print the number of seconds since reset:
  //lcd.setCursor(0, 1);
  //val = analogRead(analogPin);
  //lcd.print(val/204.8);
  //lcd.print(millis()/1000);
  //lcd.print(" V");
  //lcd.setCursor(7, 1);
  if(button1.uniquePress()){
    Serial.println("B1");
   button1Presses = ++button1Presses % NUMBER_OF_STATES1;
     switch (button1Presses) {
	case 0: lcd.clear();
                lcd.setCursor(4, 0);
                lcd.print("SET TEMP");
                Serial.println("Case0");
        case 1: lcd.clear();
                lcd.setCursor(2, 0);
                lcd.print("SET SELECTOR");
                Serial.println("Case1");
                if(button3.uniquePress()){
                  Serial.println("B2");
                    button3Presses = ++button3Presses % NUMBER_OF_STATES2;
                   switch (button3Presses) {
	            case 'sel1':
                          lcd.clear();
                          lcd.print("SELECTOR1");
                    case 'sel2':
                          lcd.clear();
                          lcd.print("SELECTOR2");
        case 2:
                 lcd.clear();
                do {
                  button1State = digitalRead(button1Pin);
                  //lcd.clear();
                  lcd.print("TEMP: ");
                  delay(10);
                } while (button1State == LOW);
                Serial.println("Case2");
What is wrong in my code?
Not a complete code. What is button.h? Rest of your code?
Plenty of things don't make sense if you don't include all you code.
FYI, I have this complete menu and interaction code.
ok,
This is the complete code:
// http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal440.h> //libraria 4x40 disp 1x16 ca 2x8
#include <Button.h> // libraria button.h
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(11, 6, 12, 7, 8, 9, 10);
//caractere
byte newChar1[8] = {
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111
byte newChar2[8] = {
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111
byte newChar3[8] = {
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111
byte newChar4[8] = {
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
byte newChar5[8] = {
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
byte newChar6[8] = {
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
byte newChar7[8] = {
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
int analogPin = 3; //pin pot
int ledPin = 13; // led pin
int button1Pin = 5;
int button1State = 0;
Button button1 = Button(5,PULLUP); //butonul0 la pin 2 dig
Button button2 = Button(2,PULLUP); //butonul1 la pinul 3 dig
Button button3 = Button(3,PULLUP); //butonul0 la pin 2 dig
Button button4 = Button(4,PULLUP); //butonul0 la pin 2 dig
byte button1Presses = 0; // variabila pt butonul1
byte button2Presses = 0; //variabila pt butonul2
byte button3Presses = 0; //variabila pt butonul3
byte button4Presses = 0; //variabila pt butonul4
const byte NUMBER_OF_STATES = 8; // numar stari butonul0
const byte NUMBER_OF_STATES1 = 3;
const byte NUMBER_OF_STATES2 = 2;
int val = 0;
  // set up the LCD's number of columns and rows:
  lcd.begin(8, 2);
  pinMode(ledPin, OUTPUT);
  pinMode (button1Pin, INPUT);
  lcd.createChar(0, newChar1);
  lcd.createChar(1, newChar2);
  lcd.createChar(2, newChar3);
  lcd.createChar(3, newChar4);
  lcd.createChar(4, newChar5);
  lcd.createChar(5, newChar6);
  lcd.createChar(6, newChar7);
  //lcd.write(0);
   state();
    void state() {
  //lcd.print(" V");
	            case 'sel1':
                          lcd.clear();
                    case 'sel2':
                          lcd.clear();
        case 2:
                 lcd.clear();
                do {
                  //lcd.clear();
                  delay(10);
  if(button4.uniquePress()){
   button4Presses = ++button4Presses % NUMBER_OF_STATES;
     switch (button4Presses) {
	case 0: lcd.write(0);
        digitalWrite(ledPin ,LOW);
        case 1: lcd.write(1);
        digitalWrite(ledPin ,HIGH);
        case 2: lcd.write(2);
        case 3: lcd.write(3);
        case 4: lcd.write(4);
        case 5: lcd.write(5);
        case 6: lcd.write(6);
  delay(30);
This doesn't look good:
	            case 'sel1':
                          lcd.clear();
                    case 'sel2':
                          lcd.clear();
Compare it to your other case statements where you've used integer constants.
I think I'm blind, I can not see what is wrong.........
In the code fragment above, button3Presses will be either 0 or 1, those are what your case statements should be testing, not 'se1' and 'sel2'
ok.
I tried it, does not work
When switch (first one) is in case 1: it must wait for this piece of code:
                  Serial.println("B2");  //debug
	            case 0:
                          lcd.clear();
                    case 1:
                          lcd.clear();
if button3 is pressed I must have a "B2" on serial, and SELECTOR1 on LCD.
they do not happen..
code again
//custom char
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
int button1Pin = 5;
int val = 0;
  lcd.begin(8, 2);
  //lcd.write(0);
    Serial.println("B1"); //debug
                Serial.println("Case0"); //debug
                Serial.println("Case1");  //debug
	            case 0:
                          lcd.clear();
                    case 1:
                          lcd.clear();
        case 2:
                 lcd.clear();
                do {
                  //lcd.clear();
                  delay(10);
                Serial.println("Case2"); //debug
  delay(30);
I found a solution, maybe not the best but it works,
problem was that switch / case is no loop.
//custom char
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111
	B00000,
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111
	B00000,
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
	B00000,
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
	B00000,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
int button1Pin = 5;
int incomingByte = 0; //debug
int val = 0;
  lcd.begin(8, 2);
  //lcd.write(0);
        case 1: //lcd.clear();
                do {
	            case 0:
                          lcd.clear();
                    case 1:
                          lcd.clear();
        case 2:
                 lcd.clear();
                do {
                  //lcd.clear();
                  delay(10);
  delay(30);
