LCD Screen / Relay Module with water pump
Hi everybody. If there is a place for this thread that is not here I apologise. I have been writing code and adding to my circuit as I've been going along and it was all ok until recently, when the 4 relay module arrived. My code was working with my sensors and printing to the LCD. When I connected the relay and the water pump, and added the 2 IF statements below it scrambles the LCD. My circuit works (adding water and stopping when I've asked) which makes me think the IF statements are ok. This would be my first IF statements ive coded so they might have issues but as far i know right now its fine. When I disconnect the relay module and upload again the LCD comes back to normal. which makes me think the IF statements are fine and its a problem with how ive got the relay wired or how my print.lcd command is interacting with the code? can anyone see a glaring error in this code that would mess my LCD up? Thanks, Grant
#include<DHT.h> //DHT library
#define Type DHT11
int sensePin = 2;
DHT HT(sensePin, Type);
float humidity;
float tempC;
float tempF;
int delayTime = 1000;
#include<LiquidCrystal.h>
int rs = 7;
int en = 8;
int d4 = 9;
int d5 = 10;
int d6 = 11;
int d7 = 12;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
const int wetA = 195; //sensor value when wet
const int dryA = 525; //sensor value when dry
  pinMode(4, OUTPUT);
  HT.begin();
  lcd.begin(16, 2);
  int sensorA = analogRead(A2);
  int sensorB = analogRead(A3);
  int sensorC = analogRead(A4);
  int sensorD = analogRead(A5);
  int percentageA = map(sensorA, wetA, dryA, 100, 0);
  int pumpAstate = digitalRead(4);
  humidity = HT.readHumidity();
  tempC = HT.readTemperature();
  Serial.print("Humidity=");
  Serial.print(humidity); //print humidity from DHT
  Serial.print("% ");
  Serial.print("  Temperature=");
  Serial.print(tempC); //Print Temp C from DHT
  Serial.print("C ");
  Serial.print("  Soil Moisture Content A=");
  Serial.print(percentageA); //print soil moisture percentage
  Serial.print("% ");
  Serial.print("  Current sensor A value for calibration=");
  Serial.print(sensorA); //Print value from soil sensor A
  Serial.print(" ");
  Serial.print("  Pump A ON/OFF=");
  Serial.println(pumpAstate); //Pump On/Off
  if (percentageA < 20) {
    digitalWrite(4, LOW); //when below 20% pin 4 low/pump on
  if (percentageA > 60) {
    digitalWrite(4, HIGH); //when above 60% pin 4 high/pump off
  lcd.setCursor(0, 0);
  lcd.print("T=");
  lcd.print(tempC);
  lcd.print("C ");
  lcd.print("H=");
  lcd.print(humidity);
  lcd.print("%");
  lcd.setCursor(0, 1);
  lcd.print("A");
  lcd.print(percentageA);
  lcd.print("%");
  lcd.print("  Pump ON =");
  lcd.print(pumpAstate);
Always show us a good schematic of your proposed circuit.
Show us good images of your ‘actual’ wiring.
Give links to components.
From my experience, I2C LCDs are much much less susceptible to EMI.
How are you powering the relays? If you are using your laptop/computer via usb to power the relays they might not have enough power to run hold them open/closed and could cause weird things to happen when the if statement goes to turn on a pump and hold a relay open/closed.
Ill get one drawn tomorrow and give the breadboard a tidy up and post more info to update the post. thanks
Yes using laptop. I will try other power supply tomorrow and update. Thanks
quick update. I have moved my components to multiple breadboards and gave everything some space, with the lcd screen as far from the relay module as I can get it and it is working well. It was very cluttered.
At first glance, it looks like you are powering the relay module from the Arduino.
If this is the case, you should not do this.
The Arduino should not be used to power relay modules.
4 channel relay modules should be connected as below:
So I got a bit excited last night it seems @LarryD
When I got in this morning the fault had never left. I must have been sleepy when I tested and reported back bad data. I should also know better about my relay connections. Thanks for letting me know :smiley:
I have rewired the circuit to your relay diagram suggestion.
@LarryD @fshausb Thank you very much for taking the time to give me some info. Much appreciated.
turns out the pump i ordered was 3v and not 5v as i had it wired into.
