LDR, LEDs and Push button
I'm still new to arduino, I want to turn on ledRed when the ldrStatus goes below 900 but I want it to stay on until I press the button when at that point the ledRed will turn off and ledGreen will come on.
With the ledGreen I want that to go be on when ldrStatus is above 900 and ledRed to be off.
What's the best way to do this?
Thanks
const int ldr = A0; //ldr pin A0
const int ledRed = 13; //red Led pin 13
const int ledGreen = 12; //green Led pin 12
const int pushButton = 2; //pushButton in pin 2
int buttonState = 0; //variable for reading pushButton Status
  pinMode(ldr, INPUT);
  pinMode(ledRed, OUTPUT);
  pinMode(ledGreen, OUTPUT);
  pinMode (pushButton, INPUT);
  int ldrStatus = analogRead(ldr);
  buttonState = digitalRead(pushButton);
  if (ldrStatus <= 900) {
    digitalWrite(ledRed, HIGH);
    digitalWrite(ledGreen, LOW);
    Serial.print("FAIL");
    Serial.println(ldrStatus);
  else {
    digitalWrite(ledGreen, HIGH);
    digitalWrite(ledRed, LOW);
    Serial.print("VALID");
You need a boolean to track the "alarm" state as I call it. Here is my take take on it. It compiles but I have not fully tested it. Also, I changed the button to INPUT_PULLUP and assumed the pressed state was LOW. Yours may be wired differently.
int lastButtonState;
bool ldrAlarm = false;
bool lastLdrAlarm = false;
  pinMode(pushButton, INPUT_PULLUP);
  lastButtonState = digitalRead(pushButton);
  int buttonState = digitalRead(pushButton);
  if (buttonState != lastButtonState)
    delay(50); // debounce
    lastButtonState = buttonState;
    if (buttonState == LOW)
      ldrAlarm = false;
    ldrAlarm = true;
  else {
  if (ldrAlarm != lastLdrAlarm) {
    lastLdrAlarm = ldrAlarm;
    if (ldrAlarm) {
      Serial.print("FAIL ");
    else {
consider
#if 0       // my hardware
const int pushButton = A1;
#else
#endif
    pinMode (pushButton, INPUT_PULLUP);
    buttonState = digitalRead (pushButton);
    int but       = digitalRead(pushButton);
    else if (buttonState != but)  {
        buttonState = but;
        if (LOW == but)  {
Thanks both of these worked!
Now to learn boolean logic.
Thanks
