Lead-acid battery - what one??
For a project I am looking for a lead-acid (or other) 12V battery that can handle currents from 0-2A with peaks of 6-10A. It should last at least an hour. Size doesn't matter, as long as I can take it with me. My budget is ?40, but less is preferred :slight_smile:
For longevity of the battery you should look to limiting depth of discharge to no more than 20% of capacity.
So if you want 1 hour at a nominal mean of 5 amps you need a battery of 5x1/.2 or 25AH. This should be capable of giving a peak of 10 amps without too much dip.
I would suggest an SLA (sealed lead acid) golf caddy battery might meet your needs - and becasue it's sealed , and be inverted without losing its contents - though ideally it should be used the correct way up.
jack
The prize structure might be different in Europe; but what I have in my catalogs is:
7.2 Ah 17 Euro 2.6 kg
12 Ah 38 Euro 3.8 kg
24 Ah 79 Euro 8.6 kg
Kung Long is a little bit cheaper than Panasonic
Would a 10AH battery be able to withstand 10A?
;D Of course it will! Think of cranking motors!
BTW:You will always find valuable information in datasheets
Thank you!
And what loader should I use?
Before you can accurately determine the battery size required (to avoid both over and undersizing) you really need to establish what your load profile trully is.
For example 0-2amps means didly squat. Do you mean mostly 0 or mostly 2. Occassionally 6 to 10 means what - a spike once a blue moon or regular and sustained loads of these values for periods of time.
jack
The load depends entirely on your application. I would ask what load do you have or what load do you need.
I think he means "charger".
Yeah, you're right :slight_smile: Sorry, I'm not a native English speaker...
Lead batteries are notorious for being chargeable through a resistor only :-) But take care....
Edit
Of course, there is more good information
