Learning to use strcmp with two array values, compile error
I'm trying to compare two array values, one originates as a const char*, the other is saved as a String (to make things work in this simple first draft).
I'm trying to see if there is a stored value in the array named onList[] like "Bin 4" for example. I'm storing values in the onList[] temporarily to display a short list of active inputs (which is working). Everything is working, except I need to know if an item is already in the onList[] or not.
My code
const char* arInput[]={"Bin 1", "Bin 2", "Bin 3", "Bin 4", "Bin 5", "Bin 6", "Bin 7", "Bin 8", "Bin 9", "Bin 10", "Bin 11", "Bin 12"};
String onList[12]; // examples: "Bin 2", "Bin 4", etc.
byte check_onList(byte col){ // -------- Function to know if input is in onList or not -----------
    if (strcmp(onList[0], "Bin 4")== 0) { // compile error line
     // if (strcmp(onList[0], arInput[i])== 0) {  // alternate comparison
      //int strcmp(const char *str1, const char *str2) // example
      return 1;}
    else {
      return 0;
I'm getting the compile error:
cannot convert 'String' to 'const char*' for argument '1' to 'int strcmp(const char*, const char*)'
what is the correct method/syntax?
Greatly appreciated.
String objects and C-strings are almost entirely unrelated. Best to avoid Strings on Arduino, as they cause memory problems and even program crashes.
Except that it can't. Working example:
const char * roomList[] = {"Bath", "Bed", "Beyond", "Closet"};
  for (int i = 0; i < 4; i++)
    if (strcmp("Bed", roomList[i]) == 0) {
      Serial.print("match at index ");
      Serial.println(i);
void loop() {}
I understand this is not what you are looking for, but if your const array (in flash) is in sorted order, then you can approach the search as a binary-search, cutting the search time by half (average.)
My old example is just brute-force. I have attached an ESP8266 sketch that takes searches to the next level by building indexing.
Spiff_OUI-13.zip (244.3 KB)
I understand the String onList[12] should be a char to match the source data array, arInput[], but days back when I was roughing this in, I had the char onList[12] and I could not push arInput[i] values directly into it, until I made it a String array. I have corrected it.
char * onList[12];
Well, to actually answer the question that OP asked, try:
    if (strcmp(onList[0].c_str(), "Bin 4")== 0) {
This will provide a pointer to the c-string contained in the String object. That's what strcmp() needs for both arguments.
So, now with strcmp I'm trying to use a function with a value passed, to compare the passed value to an array value. So knowing there is a certain value (Bin 1) in this location: onList[0], I'm testing the below code which gives 0 response regardless of onList[] contents..
char * onList[12];
byte check_onList(char on){ // -------- See if an input listed or not -----------
      Serial.println(on);  // Displays an "i" , not 'Bin 1' as expected, ?
    for (int io = 0; io < 4; io++) {
    if (strcmp(on, onList[io])== 0) {
      Serial.print("Match at index ");
      Serial.println(io);
     // return 1;}
      // else {
       //  return 0;
button2State = digitalRead(inPin2); //----------- Clear onList Button -------------------
if (button2State == LOW) {
    // clear_onList(); //----- Clear onList Array values -----
     //dispOnList();
      Serial.println(check_onList("Bin 1")); // Returns '0' while onList[0] has 'Bin 1' value
That shouldn't even compile let alone work. The function prototype for strcmp() is:
int strcmp( const char *lhs, const char *rhs );
Both arguments must be of type 'char *' (pointer to char). And, the string pointed to must be null-terminated. Your 'on' variable is not a 'char *'.
Thanks gfvalvo,
Its working!
Please post the working code.
my current test code:
char * onList[12];
byte check_onList(char * on){//(byte col){ // -------- See if an input listed or not -----------
  //Serial.println(on);
  for (int io = 0; io < 12; io++) {
    if (int(strcmp(on, onList[io])== 0)) {  //if (strcmp("Rm xx", arInput[i])== 0) {
     // Serial.print("Match at index ");
     // Serial.println(io);
      return 1;} // found in onList[]
       else {
        return 0; // not found in onList[]
I'm trying to understand why my
function returns a '0' regardless of input. I think this method/example was returning the index value, maybe not the '0' for actual string match, '-1' no match, etc.
I seriously doubt that code works. It returns 0 on the first non-match without checking the entire array. Try:
byte check_onList(char * on) { //(byte col){
    if (int(strcmp(on, onList[io]) == 0)) { //if (strcmp("Rm xx", arInput[i])== 0) {
      return 1;
  return 0;
That fixed it!
Thanks gfvalvo
char * onList[12];  // holds active inputs that are ON, to be displayed
const int inPin2 = 7;
int button2State = 0;
byte check_onList(char * on){  // ----- Is Input in onList[] or not? ---
      return 1;
    return 0;
button2State = digitalRead(inPin2); //----------- Test Button 2 -------------------
      Serial.println(check_onList(arInput[1]));  // 'Bin 2' value in arInput[1] location
So sending check_onList(char * on) with either a literal "value" or a value from the reference array like arInput[2] now results in a '1' if the value is in the onList[] array, or a '0' if the value is not in the in the onList[] array.
My end goal is temporarily logging and displaying the input status of a Modbus digital input module. Maybe the next version will permanently log each event with date/time.
There is no need to cast the result the call as the function returns a number, it's OK to compare it with 0 directly
       if (strcmp(on, onList[io]) == 0) {
