You will need Spectrum Shield from SparkFun
Run this code to make sure all of your LEDs work
int colpin1 = 7;
int colpin2 = 8;
int colpin3 = 9;
int colpin4 = 10;
int colpin5 = 11;
int colpin6 = 12;
int colpin7 = 13;
int rowpin1 = 6;
int rowpin2 = A2;
int rowpin3 = A3;
int rowpin4 = A4;
int rowpin5 = A5;
int strobe = 4; // strobe pins on digital 4
int res = 5; // reset pins on digital 5
int left[7]; // store band values in these arrays
int right[7];
int band;
pinMode(res, OUTPUT); // reset
pinMode(strobe, OUTPUT); // strobe
pinMode(colpin1, OUTPUT); // strobe
pinMode(colpin2, OUTPUT); // strobe
pinMode(colpin3, OUTPUT); // strobe
pinMode(colpin4, OUTPUT); // strobe
pinMode(colpin5, OUTPUT); // strobe
pinMode(colpin6, OUTPUT); // strobe
pinMode(colpin7, OUTPUT); // strobe
pinMode(rowpin1, OUTPUT); // strobe
pinMode(rowpin2, OUTPUT); // strobe
pinMode(rowpin3, OUTPUT); // strobe
pinMode(rowpin4, OUTPUT); // strobe
pinMode(rowpin5, OUTPUT); // strobe
digitalWrite(res,LOW); // reset low
digitalWrite(strobe,HIGH); //pin 5 is RESET on the shield
spec(colpin1, 5);
spec(colpin2, 5);
spec(colpin3, 5);
spec(colpin4, 5);
spec(colpin5, 5);
spec(colpin6, 5);
spec(colpin7, 5);
void readMSGEQ7()
// Function to read 7 band equalizers
digitalWrite(res, HIGH);
digitalWrite(res, LOW);
for(band=0; band < 7; band++)
digitalWrite(strobe,LOW); // strobe pin on the shield - kicks the IC up to the next band
delayMicroseconds(30); //
left[band] = analogRead(0); // store left band reading
right[band] = analogRead(1); // ... and the right
void spec(int col, int height)
digitalWrite(colpin1, HIGH);
digitalWrite(colpin2, HIGH);
digitalWrite(colpin3, HIGH);
digitalWrite(colpin4, HIGH);
digitalWrite(colpin5, HIGH);
digitalWrite(colpin6, HIGH);
digitalWrite(colpin7, HIGH);
digitalWrite(col, LOW);
digitalWrite(rowpin1, LOW);
digitalWrite(rowpin2, LOW);
digitalWrite(rowpin3, LOW);
digitalWrite(rowpin4, LOW);
digitalWrite(rowpin5, LOW);
//for height
if(height > 0)
digitalWrite(rowpin1, HIGH);
if(height > 1)
digitalWrite(rowpin2, HIGH);
if(height > 2)
digitalWrite(rowpin3, HIGH);
if(height > 3)
digitalWrite(rowpin4, HIGH);
if(height > 4)
digitalWrite(rowpin5, HIGH);
delay(2);
This code using Multiplexing to light up to audio
by Ody
12-2015
int colpin1 = 7;
int colpin2 = 8;
int colpin3 = 9;
int colpin4 = 10;
int colpin5 = 11;
int colpin6 = 12;
int colpin7 = 13;
int rowpin1 = 6;
int rowpin2 = A2;
int rowpin3 = A3;
int rowpin4 = A4;
int rowpin5 = A5;
int right[7];
int band;
digitalWrite(res, LOW); // reset low
digitalWrite(strobe, HIGH); //pin 5 is RESET on the shield
readMSGEQ7();
// display values of left channel on serial monitor
for (band = 0; band < 7; band++)
Serial.print(left[band]);
Serial.print(" ");
Serial.println(" - Left ");
// display values of right channel on serial monitor
Serial.print(right[band]);
Serial.print(" ");
Serial.println(" - Right" );
spec(colpin1, left[0]);
spec(colpin2, left[1]);
spec(colpin3, left[2]);
spec(colpin4, left[3]);
spec(colpin5, left[4]);
spec(colpin6, left[5]);
spec(colpin7, left[6]);
spec(colpin1, right[0]);
spec(colpin2, right[1]);
spec(colpin3, right[2]);
spec(colpin4, right[3]);
spec(colpin5, right[4]);
spec(colpin6, right[5]);
spec(colpin7, right[6]);
void readMSGEQ7()
digitalWrite(strobe, LOW); // strobe pin on the shield - kicks the IC up to the next band
// function that lights of a column depending on height
//for height
if (height > 73)
if (height > 80)
if (height > 100)
if (height > 120)
if (height > 140)
delay(2);
