LED blink between 2 boards
As a newbie, I have been working on this sketch for over a week and I think I need help.
I have 2 boards connected via nRF24L01. I want the Transmitter to send a signal to the Receiver when a tilt switch is changed. This will set a LED on the Receiver to blink. I have succeeded this with the help of the examples on the web.
What I cant do is keep the LED blinking and reset it with a button push on the Receiver end.
I have enclosed the sketches but I removed the button part of the Receiver sketch for clarity.
I would appreciate any help.
Many thanks
Transmitter sketch:
 #include <SPI.h>
    #include <nRF24L01.h>
    #include <RF24.h>
    RF24 radio(9, 10); // CE, CSN
    const byte address[6] = "00001";     //Byte of array representing the address. This is the address where we will send the data. This should be same on the receiving side.
    int button_pin = 2;
    int transbuttonCounter = 0;
    int lastButtonState = 0;
    boolean button_state = 0;
    pinMode(button_pin, INPUT);
    radio.begin();                  //Starting the Wireless communication
    radio.openWritingPipe(address); //Setting the address where we will send the data
    radio.setPALevel(RF24_PA_MIN);  //You can set it as minimum or maximum depending on the distance between the transmitter and receiver.
    radio.stopListening();          //This sets the module as transmitter
    button_state = digitalRead(button_pin);
    //if (transbuttonCounter != lastButtonState) {
       if(button_state == HIGH) {
      // transbuttonCounter++;
        const char text[] = "Button State Trans is HIGH/Flash";
       radio.write(&text, sizeof(text));                  //Sending the message to receiver
       } else
          const char text[] = "ButtonState Transmit is LOW";
          radio.write(&button_state, sizeof(button_state));  //Sending the message to receiver
         if (transbuttonCounter % 1 == 0) {
          digitalWrite (button_pin, HIGH);
         digitalWrite(button_pin, LOW);
//    }// new IF Counter
Receiver sketch:
 #include <SPI.h>
    #include <RF24.h>
    // new varibles for button section
    boolean button_2 = 0;
    int led_pin = 3;
    int buttonPin = 7;
    // new varibles from millis
      unsigned long previousMillis = 0;
      const long interval = 1000;
      int ledState = LOW;
     pinMode(3, OUTPUT);
     pinMode(7, INPUT);   // initialize the pushbutton pin as an input:
      radio.begin();
      radio.openReadingPipe(0, address);   //Setting the address at which we will receive the data
      radio.setPALevel(RF24_PA_MIN);       //You can set this as minimum or maximum depending on the distance between the transmitter and receiver.
      radio.startListening();              //This sets the module as receiver
      } //endSET UP
        //digitalWrite(buttonPin, HIGH);
      if (radio.available())     {         //Looking for the data.
      char text[32] = "";                 //Saving the incoming data
      radio.read(&text, sizeof(text));    //Reading the data
      radio.read(&button_state, sizeof(button_state));    //Reading the data
       if(button_state == HIGH) { /// from Transmitter {
       Serial.println(text); // text from Transmitter
          // flashes the LED
        if (currentMillis - previousMillis >= interval) {
       // save the last time you blinked the LED
       // if the LED is off turn it on and vice-versa:
       if (ledState == LOW) {
        ledState = HIGH;
        ledState = LOW;
        // set the LED with the ledState of the variable:
        digitalWrite(led_pin, ledState);
        } else
      digitalWrite(3, LOW);
      //digitalWrite(7, LOW);
      Serial.println("button on TRANS not pressed");
      //digitalWrite(button_2, LOW);
            } // if RAdio..
     delay(50);
      } // void loop
You are close! You want to check the led blinking/not blinking outside of receiving radio data. You also want to check the state of your button press on the receiver outside of the radio receiving data.
This code should get you close:
#include <SPI.h>
#include <RF24.h>
boolean button_state = false;
boolean led_running = false;
const int led_pin = 3;
const int buttonPin = 7;
int ledState = LOW;
  pinMode(led_pin, OUTPUT);
  pinMode(buttonPin, INPUT);   // initialize the pushbutton pin as an input:
  radio.begin();
} //endSET UP
  // flashes the LED, if running
  if ( led_running == true ) {
        ledState = HIGH;
        ledState = LOW;
    if (button_state == HIGH) { /// from Transmitter {
      led_working = true;   // start flashing LED
    } else
      led_working = false;   // stop flashing LED
    digitalWrite(led_pin, LOW); // and make sure it is off
    if ( digitalRead( buttonPin ) == HIGH ) {
      // reset LED
      Serial.println("button on RX pressed");
Note: The typical way to wire up a button is to connect one side to a digital pin and the other to ground. You then enable the Arduino internal pullups such that the pin reads HIGH when not pressed and LOW when it is pressed and shorted to ground. Your code does not do that but I don't know how you have your button wired. If you have on one side of the button tied to +5V and the other to the digital input pin, you need an external pulldown resistor to make it work.
Many thanks, I’ll try that tomorrow
