i am trying to light up an LED for 3 seconds when there is a value "1" in the serial port and turn it off afterward. when there is no value, then the LED is off. i've made this code but it only turns the LED on constantly.
please help.
 const int ledPin = 13;   // the pin that the LED is attached to
 long previousMillis=0; //previous millisecond
 unsigned long currentMillis = 0;//current millisecond
 int SerialValue=0;
Â
Â
Â
 // initialize the serial communication:
 // initialize the ledPin as an output:
 pinMode(ledPin, OUTPUT);
 SerialValue=0;
 previousMillis =0;
 currentMillis =0;
 if (Serial.available()) {
  SerialValue = Serial.read();
  if (SerialValue == '1') //if SerialValue = 1, turn LED on for 3 seconds
   previousMillis = millis();
    currentMillis = millis();
  while(currentMillis - previousMillis <= 3000)
    digitalWrite(ledPin,HIGH);Â
    digitalWrite(ledPin, LOW);//turn LED off after 3 seconds
  else //if SerialValue is not = 1, LED off
what do you mean by blocking? i have read that i shouldn't use delay because it cannot sense if there is a switch pressed.i was planning on putting a switch to halt the lighting of the LED. so that i can immediately turn off the LED even if three seconds have not passed yet.
How would you turn the LED on and off manually, using nothing but a watch (millis()), a pencil and a piece of paper?
Turn the LED on. Write down the time. Periodically, check the time.
If enough time has passed, turn the LED off, and write down the time.
You don't need to just stand there doing nothing in between turning the LED on or off.
But, that is what you have your code doing. Turn the LED on. Do nothing until it is time to turn the LED odd. Turn it off. Do nothing until it is time to turn the LED on again. You might as well be using the "do-nothing-until" function, also known as delay.
Look at, and understand, the blink without delay example.
yes, i have looked at the blink without delay function. but it only does the blinking without specified time of how long to turn an LED on. i want that the LED be on for 3 seconds.
you're right but that is not what i meant. i mean that, like in the code i posted, i need that the LED will be on for 3 seconds and then off. the LED will only light up again if there is another "1" in the serial port. but the example in the blink without delay, it is in a continuous loop having 1 second interval for the on and off times.
Below is some test code I tweeked that might work for you.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
    pinMode(13, OUTPUT);
    Serial.println("serial test 0021"); // so I can keep track of what is loaded
    while (Serial.available()) {
    delay(1);Â
  if (Serial.available() >0) {
    char c = Serial.read();
    readString += c;}
   Â
   if (readString.length() >0) {
   Serial.println(readString);
 Â
  if (readString == "1") {
digitalWrite(13, HIGH);
    Serial.println("Led On");
    delay(3000);
    digitalWrite(13, LOW);
    Serial.println("Led Off");
     readString="";
