Led lightbar for snowblower lighting but not dimming n
Hi. I saw a pwm and capacitors mentioned on this forum under a Google search. I hope its ok. To post this.
I have a snowblower. Power supply to a toggle then to a rectifier and then to two capacitors. I saw it on YouTube. At the end is a truck led lightbar for snowblowing at night. I have a pwm right before the light bar. It still lights the bar but wont dim. Any help is greatly appreciated. Thank you
Ive read the snowblower produces ac.
Im pretty sure its connected right. It lights up but wont dim. Toggle works. Im hoping the pwm was too high voltage. I ordered a 5 to 24 v new one. The old pwm was 12 to 24. 30 amp
This is what i have. Lightbar works but wont dim. Thank you so much.
I dont know how to do a drawing im sorry.
Do you have any drawings or schematics, and the specs for the components you are using?
Is this a coding/microcontroller project? Or just a general wiring question?
Either way you need to provide more info.
The manufacturer will know what you need. Also, use the model, year, dimensions... to search for your item, or try a generic replacement and hope for the best...
https://www.homedepot.com/p/MTD-Genuine-Factory-Parts-LED-Light-Bar-Kit-for-Select-Snow-Blowers-753-08484/326959475
Welcome!
I do not have a clue as to what you have, it is like saying what battery do I need? We are not clairvoyant, we cannot see, touch, feel etc what you have. It is your job to give us enough information to help you. You can start by posting links to the technical descriptions of each item.
You have some bits and pieces that may or may not work together.
Firstly, PWM (Pulse Width Modulation) is a method, not a thing.
A dimmer control might use PWM and be described as a PWM controller.
Why not try the controller you have with a simple load like a small filament lamp?
This will establish if the controller is working.
It's likely that the lightbar, details would help, has electronics in it that might or might not support dimming.
Plain LEDs will dim quite successfully using the PWM output of an Arduino board.
For mains voltage LED lighting, dimming isn't wonderful. Even when you match a dimmer with a dimmable (dimmable and non-dimmable types available) lamp, they often don't work well.
You don't need the rectifier, capacitors or even the switch.
Just connect the 12V battery and the LED bar to the dimmer.
Hi, @avandergoot
Welcome to the forum.
Do you have a DMM? Digital MultiMeter?
Tom.... :smiley: :+1: :coffee: :australia:
I have a dc pwm
And a multimeter
Have you conneced it the correct way as explained?
Post some information on the snowblower, brand name & model number, link to user manual, etc.
This might explain a lot (the text in red)
What a piece of junk
Thanks Jim i think its correct. Ive tried different variations. Im wondering if a lower power voltage dimmer is it? I ordered a 5 to 24v. First of one was 12 to 24. Should I try it?
Thank you im not sure about dimming ability of the lightbar yet. This guy with 50k hits on YouTube did it with a much larger lightbar . It worked. The snowblower produces ac without having the rectifier
@avandergoot You marked post 5 as the solution. What exactly was the solution?
Sorry i thought it was a thumbs up type thing. New pwm coming tomorrow. 5 to 24v
@avandergoot
Did you read post #11 ?
Not exactly a high quality device.
If the snowblower has an alternator driven by the main engine, it will output AC.
In a normal car, it has a regulator pack of diodes and a voltage regulator.
The regulator pack supplies the battery, say 12-V, and the battery supplies the car electrics.
Does the blower have a battery? Quite likely for starting.
That battery is the source of your DC supply.
You need to give more information about the snowblower so people know what they are dealing with.
Who's the guy with 50K hits?
As for the solution, I can't offer a solution without full details of the problem.
Dimming LEDs isn't a big deal, it's just a matter of selecting the correct items.
If you have a DC supply, then a PWM controller will work.
Whether it works with your lightbar is another matter.
Don't bother, see post #11
Snowblower does not have a battery. Pull start and plug in electric starter
Do you know the difference between AC and DC? I am not trying to be a jerk. It’s a legit question.
