Hi all,
I made an LED array with SMT LED's. The circuit is 9 sets of one each, red, green and blue, each set in series and running on 12 volts through a 150 ohm resistor. The V forward of the LED's are:
red: 2.1V
green: 3.2V
blue: 3.2V
The series current for each set is, therefore 23.3 milliamps. See attached image.
Since each LED is rated for the same output luminance (brightness), I expected the board to produce basically white light. Yet, the light has a blue-cyan cast to it (even looks blue compare to daylight).
It seems as though the blue and green LED's are brighter than the red ones (although the specs say otherwise).
Anyone know why this is? Is the light really white, but looks blue to my eyes due to differences in wavelength sensitivity of the eye? Is the red not as bright as the other two?
Any ideas will be appreciated. I ultimately need to be able to get a balanced white light output from this board. This one is a test, but I plan to build a much larger one when I get it all figured out.
Thanks!
