J-M-L
April 18, 2021, 8:14pm
21
I've looked at the video. I don't actually see what you mean, the fading might be fast since there is no pause, counting to 255 is like 123 cycles.
Remember also that code goes to dark, make a quick pause, and then fade again from full bright.
In any case, here is a version with a small state machine, it's cleaner
#include <FastLED.h>
#define NUM_LEDS 30
#define DATA_PIN 5
CRGB leds[NUM_LEDS];
const byte buttonPin = 7;
enum : byte {STOPPED, RUNNING, PAUSING} currentState = PAUSING;
const int deltaStep = 5;
const int startingColor = 255;
int colorStep = startingColor;
unsigned long pauseStartTime;
const unsigned long pauseDuration = 1000; // in ms ie 1 second
void fillStrip(byte c) {
for (byte px = 0; px < NUM_LEDS; px++) leds[px] = CRGB(0, c, 0);
FastLED.show();
void black() {
FastLED.clear();
FastLED.show(); // not sure if this is neeed after clear
void manageStrip() {
if (digitalRead(buttonPin) == HIGH) { // button not pressed
if (currentState != STOPPED) {
black();
currentState = STOPPED;
} else { // button pressed
switch (currentState) {
case STOPPED: // we were stopped and button got pressed, start running
fillStrip(colorStep); // start where we left off
currentState = RUNNING;
case RUNNING:
colorStep -= deltaStep;
if (colorStep <= 0) {
pauseStartTime = millis();
case PAUSING:
if (millis() - pauseStartTime >= pauseDuration) {
pinMode(buttonPin, INPUT_PULLUP); // wire pin D7 --- button --- GND
FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
black();
manageStrip();
if you want to slow things down to see what's going on, change the fillStrip() function into
FastLED.show();
delay(100); // 10 Hz update
Hi Jean-Marc,
Thank so much for the re-write. Much cleaner
Still can't get the desired effect unfortunately.
If I only tap the switch it only light on for brief moment - no fade.
If I hold the switch I get the desired effect.
I really need it to do one light up the fade every if the switch is only tapped.
Hope that makes sense.
I'm going to keep battling now but let me know if you have any other ideas. I've attached code how it stands right now.
Thanks again for all your ongoing help. Do you code for work or just for your own projects?
#define NUM_LEDS 30
#define DATA_PIN 5
const int deltaStep = 1;
const unsigned long pauseDuration = 300; // in ms ie 1 second
for (byte px = 0; px < NUM_LEDS; px++) leds[px] = CRGB(0, 0, c);
FastLED.show();
//delay(10);
void black() {
FastLED.clear();
black();
case RUNNING:
case PAUSING:
black();
manageStrip();
J-M-L
April 19, 2021, 9:04pm
23
Hi
You mean a simple touch would do a full cycle even if you donāt hold?
(Iām retired - software engineering background)
Hi Jean-Marc,
I'm Rob by the way
Yes! That's exactly what I mean. I'm trying to add debounce to the code as we speak but no luck so far...
Hope you're enjoying your own projects now you're retired Wish I'd started learning to program years ago..
J-M-L
April 19, 2021, 9:11pm
25
Hi Rob
Iāll have a look tomorrow if you donāt solve it by then.
Cool, thank you. Wish me luck!
J-M-L
April 20, 2021, 9:40am
27
so no luck?
I would go for a modification of the state machine to only check for button state when you have completed a cycle
#define NUM_LEDS 30
#define DATA_PIN 5
enum : byte {STOPPED, RUNNING, PAUSING} currentState = STOPPED;
FastLED.show();
void black() {
FastLED.clear();
case STOPPED: // we are stopped, if there is one button press, start running
if (digitalRead(buttonPin) == LOW) {
case RUNNING: // run a complete cycle, at the end check for button still pressed
black();
if (digitalRead(buttonPin) == LOW) { // button is still pressed, pause for a bit
} else { // button is no longer pressed, stop
case PAUSING:
black();
manageStrip();
(typed here, fully untested)
Hiya, battled with it till late last night to no avail...
Iām at work right now and the circuit is at home so I canāt test.
Iāll give it a go and let you know later
Do you think I could use a capacitor for this function as a hardware add on? Just wondering...
Thanks for the code! Iāll let you know how I get on
J-M-L
April 20, 2021, 10:23am
29
I don't get the question. Where would you put a cap?
I thought that the issue may be with debouncing and read that you can use caps for debouncing...
Cap goes between switch pins...
Hello !
I hope to have a lot of fun and learn many things with my Arduino Uno I got a few days ago. Before I start, I'd like to notice that I looked for the solution, there are many tutorials and short explanations about how to handle button bounces on hardware level. Sadly, I did not find anything that could be wrong so I decided to create a new topic (though I know this must be some stupid mistake of mine).
What I wanna do is a circuit with 2 LEDs (and a resistor for each of course) and a buā¦
J-M-L
April 20, 2021, 12:03pm
32
ah - OK sure you could, it does not hurt but is an extra part.
I don't think it's really needed, one "flash" will probably last longer than 15/20 ms which is usually more than the bounce time of those small momentary buttons and we don't check the state again before one cycle is completed.
J-M-L:
#define NUM_LEDS 30
#define DATA_PIN 5
FastLED.show();
void black() {
FastLED.clear();
black();
case PAUSING:
black();
manageStrip();
This works great! I just modified the deltaStep and the pause duration to suit my needs but absolutely brilliant!
I will study the last code and this to try and understand the differences.
Thank you so much for all your help! Couldn't have done it without you
Here's the final code I've used - just so it's up on here.
#define NUM_LEDS 30
#define DATA_PIN 5
FastLED.show();
void black() {
FastLED.clear();
black();
case PAUSING:
black();
manageStrip();
J-M-L
April 20, 2021, 6:04pm
34
great news (I want to see the video )
have fun
Here ya go! So happy with this just wanna learn quicker! Thanks again
jean480.mov.zip (3.4 MB)
J-M-L
April 21, 2021, 8:27am
37
Nice ! thanks for the video
system
Closed
August 19, 2021, 8:27am
38
