LEDs and Light Dependent Resistors
I have a led that turns on and off. I have an LDR that should register the on and off - but it doesn't. When you turn the lights off it drops to near 0 even tho the light is flashing next to it??? Code as follows.
// pin assignments
int LDR = 0;
// initialize the serial port
// and declare inputs and outputs
pinMode(LDR, INPUT);
pinMode(13, OUTPUT);
// read from the analog input connected to the LDR
// and print the value to the serial port.
// the delay is only to avoid sending so much data
// as to make it unreadable.
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
int v = analogRead(LDR);
Serial.println(v);
delay(10);
You only sample the LDR when the LED is off. :slight_smile:
If you use millis for the timing it is easy to decouple sampling and blinking.
const byte LDR = A0;
unsigned long lastSecond, lastPrint;
  pinMode(LED_BUILTIN, OUTPUT);
  unsigned long topLoop = millis();
  if (topLoop - lastPrint >= 330) {
    lastPrint = topLoop;
    Serial.println(v);
  if (topLoop - lastSecond >= 1000) {
    lastSecond = topLoop;
    digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
While you can use 0 as a name of an analog port in analogRead, pinMode needs A0 to manage the mode of an analog pin. So this
int LDR = 0;
does not work as expected.
