Hello,
I am using a stepper demo program and a MH electronics Motor shield. The demo uses a library AFMotor.h as an include, which should send out the right things to the shiftregister and drivers of the shield.
I have a problem to understand how the AFMotor.h works. There are many defines in it and also declarations of functions, but what's inside in the functions and what is the detailed code, it is not visible. I cannot find a further include there either.
Are you using the following Motor Shield by just inserting it on the top of Arduino UNO? If yes, then collect schematic of the shield from the net, connect a DC Motor, issue command to turn the Motor in the Forward direction and then begin to study the codes to see how they interact.
Hello, yes, thank you, that explains everything. I did not know that an installation of a .h-file latently copies a cpp-file as well. But now I saw it in the library folder. Thank you again.
Dieter
