Library driver/pcnt.h doesn't work
I want to count pulses on GPIO 4 input with my ESP32. Luckily there is a driver by espressif:
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/pcnt.html
Unluckily it does not work for me. I am using platformIO with arduino framework. I have connected pin 22 and pin 4 and I can see pulses on my oscilloscope. This is my code:
#include "Arduino.h"
#include <driver/pcnt.h>
#define ARDUINO_RUNNING_CORE 1
void TaskReadPulses(void *pvParameters) // This is a task.
    (void)pvParameters;
    pcnt_config_t pcntCh1 = {
        .pulse_gpio_num = 4,
        .ctrl_gpio_num = PCNT_PIN_NOT_USED,
        .lctrl_mode = PCNT_MODE_KEEP,
        .hctrl_mode = PCNT_MODE_KEEP,
        .pos_mode = PCNT_COUNT_DIS,
        .neg_mode = PCNT_COUNT_INC,
        .counter_h_lim = 32767,
        .counter_l_lim = -32768,
        .unit = PCNT_UNIT_0,
        .channel = PCNT_CHANNEL_0,
    pinMode(22, OUTPUT);
    Serial.print("Calling unit_config: ");
    Serial.println(pcnt_unit_config(&pcntCh1));
    while (true) {
        for (int i = 0; i < 50; i++) {
            digitalWrite(22, HIGH);
            vTaskDelay(1 / portTICK_PERIOD_MS);
            digitalWrite(22, LOW);
        int16_t counterVal;
        Serial.print("Calling get_counter_value: ");
        Serial.println(pcnt_get_counter_value(PCNT_UNIT_0, &counterVal));
        Serial.print("Counter Value: ");
        Serial.println(counterVal);
        vTaskDelay(1000 / portTICK_PERIOD_MS);
    xTaskCreatePinnedToCore(
        TaskReadPulses,
        "AnalogReadA3",
        1024,
        NULL,
        1,
        NULL,
        ARDUINO_RUNNING_CORE);
void loop() {}
and this is what it returns:
Calling unit_config: 0
Calling get_counter_value: 0
Counter Value: 0
Counter Value: 0
Error code for 0 is success, so I have no idea why it does not count.
So apparently counter will not start without calling:
pcnt_counter_clear(PCNT_UNIT_0);
So there is a bug or mistake in their documentation:
" After doing setup with pcnt_unit_config(), the counter immediately starts to operate. The accumulated pulse count can be checked by calling pcnt_get_counter_value()."
