I have Arduino IDE 2.3.6. I get very annoyed that every time I open the IDE I get a window that says some libraries are not up to date and do I want to update them. I DO NOT WANT TO UPDATE THEM! I have valid reasons but the IDE does not give me the option to not be asked again and again and again. How do I stop it from constantly wanting me to update multiple libraries?
Thank you.
Hi @Southerner. If you find these notifications annoying, you can disable them via the advanced settings.
I'll provide instructions you can follow to do that:
- Press the Ctrl+Shift+P keyboard shortcut (Command+Shift+P for macOS users) to open the "Command Palette".
A menu will appear on the editor toolbar:
- Select the "Preferences: Open Settings (UI)" command from the menu.
ⓘ You can scroll down through the list of commands to find it or type the name in the field.
A "Settings" tab will open in the Arduino IDE main panel.
- Type
arduino.checkForUpdates in the "Search Settings" field of the "Settings" tab.
- Uncheck the box under the "Arduino: Check For Updates" setting.
- Close the Preferences tab by clicking its X icon.
If you disable the automatic update check, make sure to periodically do a manual check for newer versions of Arduino IDE and your installed boards platforms and libraries.
You can check for new versions of Arduino IDE by selecting Help > Check for Arduino IDE Updates from the Arduino IDE menus.
You can check for new versions of boards platforms and libraries by the following procedure:
- Select the "Arduino: Update Indexes" command from the menu.
A notification will appear at the bottom right corner of the Arduino IDE window to indicate the progress of downloading the index files which provide Arduino IDE with the information about which versions of platforms and libraries are available.
- Wait for the index file download process to finish.
- Select Tools > Board > Boards Manager... from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
- Select "Updatable" from the "Type" menu in the Boards Manager view.
A list of installed boards platforms for which updates are available will be listed.
- Click the "UPDATE" button on the entry for any platform you wish to update.
- Select Tools > Manage Libraries... from the Arduino IDE menus to open the "Library Manager" view in the left side panel.
- Select "Updatable" from the "Type" menu in the Library Manager view.
A list of installed libraries for which updates are available will be listed.
- Click the "UPDATE" button on the entry for any library you wish to update.
