I’m programming very basic circuit that uses a photoresistor and an LED. When the photoresistor senses no light from the led, it records the arduino’s millisecond count to a variable (time). When the sensor receives light from the LED it figures out the time that the sensor was blocked by taking the current millisecond count from the variable ‘time’.
Currently, there is an issue somewhere after the }else{
// I/O pins
const int sensorPin = 0; //Photoresistor - Analog Pin 0
const int ledPin = 13; // Led - Digital Pin 13
int sensorState = 0; //current state of the photoresistor
int threshold = 300; // controls the sensitivity of triggering the sensor
unsigned long time;
void setup(){
pinMode(ledPin, OUTPUT); //sets the led pin to output
digitalWrite(ledPin, HIGH); //turns on led
delay (100);
void loop(){
if (sensorState == 0){
if (analogRead(sensorPin) < threshold){ //if sensor is blocked
time = millis();
sensorState = 1;
[glow]}else{ // the error in the code is somewhere after this [/glow]
if (sensorState == 1){
if (analogRead(sensorPin) > threshold){ //if sensor is not blocked
time = millis () - time;
Serial.println("Calculating Data...Please Wait");
delay (3000); //this delay has no purpose
Serial.println (time, DEC);
sensorState = 0;
Serial.println("Ready");
When fixed, it should look something like this on the serial monitor:
Ready
(#of millis.)
Ready
Thanks,
duemilanove
