light sensor
i need some help on a school project and was wondering if some one can help. i need to make 2 light sensors to have them control 2 leds so that if i were to cover one of the leds the led should flash slower and if i put a light on the led the light should flash for for a longer time
//light sensor proget
int ledPin = 6;
int ldrPin = 0;
int lightVal = 0;
int ledPin1= 7;
int ldrPin1 = 1;
int lightVal1 = 1;
pinMode(ledPin, OUTPUT); pinMode(ledPin1, OUTPUT); }
lightVal = analogRead(ldrPin);
digitalWrite(ledPin, HIGH);
delay(lightVal);
digitalWrite(ledPin, LOW);
delay(lightVal);
lightVal1 = analogRead(ldrPin);
delay(lightVal1);
digitalWrite(ledPin1, LOW);
delay(lightVal1); }
Look at the blink without delay example.
The blink without delay example is what you should look at and make 2 of them running together.
Your problem is/will be that the the delay() function stops the program at that point (should be called stop() :)) and so will not allow you to smoothly control 2 lights at the same time. You need to implement a scheme that does not just stop the program - the example shows you how to do this with the millis() function and a few variables.
Good luck!
unsigned long time = o;
delay = 0; // the delay time
boolean led1 = FALSE; //status of led 1
int ledPin = 6;
int ldrPin = 0;
loop{
delay= analogRead(ldrPin);
if (time+delay < millis()){
  if(led1 == FALSE) digitalWrite(ledPin, HIGH); // this toggels the led, there probably is a neater way to do it but i couldnt think of it
  else digitalWrite(ledPin, LOW);
led1 != led1; // toggel the status of the led
time = millis(); // reset your timer starting point so that the next calculation
the above isn’t very neat but i think it is about what you need if you correct it,
also in your original code
dont make sense. i think you wanted the variables “ldrpin1” and “ledpin1” there.
anyway as suggested look at the timer blink example (called blink without delay i think) and you wil be good to go
one last tip: try to neatly organize your variables
the same things below eachother and in the same style
dont start counting at nothing an then jump to 1 like you did but rather start at zero then and use underscores for extra points.
int led_Pin_0 = 6;
int led_Pin_1= 7;
int ldr_Pin_0 = 0;
int ldr_Pin_1 = 1;
int lightVal_0 = 0;
int lightVal_1 = 1;
Moderator edit: Code tags added, italics tags removed.
Better still, use [code] [/code] tags when posting code
Why? CamelCase, or camelBack, is perfectly acceptable.
excuse me for not using [code ] [/code ] but obviously the underscore thingy was just a joke, i am well aware that you don't get extra points for that . . . however my advice still remains the same when using numbers in a variable title. sepparate them with a underscore form the main title. this chitchat however does not help pavel so i will not further polute this topic with none helpfull information besides this message.
Pavel, could you give us an update if you fixed youre program or still have questions/issues
