I try to control the light to turn on/off with 2 instant buttons (named b1, b2), N.O (normal opened).
These 2 buttons install on the line to limit a pointer moving in 2 directions (b2 on the left, b1 on the right). In the beginning, both lights turns OFF, the buttons are opened (as N.O).
When a pointer from the middle of line moving on the right direction, it hits b1 button (b1 closed), the Yellow light turns ON (during b2 is closed).
When the pointer leaving (changes direction to the left side), the b1 button releases (b1 is opened now), the RED light turns ON, until it hits the b2 button, the RED light turns OFF.
My problem is I can not turns OFF the RED light after the pointer living b2 button (b2 is opened) to start as beginning (all lights turns OFF). The RED light turns OFF ONLY when the b2 button is pressed.
Could you please tell me why ?
Here is my code:
* Arduino Uno R3
* 2 pushed buttons + 2 lights (Yellow, Red)
const unsigned int yellowPin = A4;
const unsigned int redPin = A5;
const unsigned int b1Pin = 11; // Buttons (with INPUT_PULLUP resistors).
const unsigned int b2Pin = 12; // Reset (no lights turn ON)
int b1, b2; // Values read from b1Pin, b2Pin pins
enum indState_t : int {
YELLOW_ON = 1, // State during yellow lights ON
RED_ON = 2, // State during red lights ON
NONE = 3 // State resetting (no lights turn ON)
} indState;
pinMode(yellowPin, OUTPUT);
pinMode(redPin, OUTPUT);
pinMode(b1Pin, INPUT_PULLUP);
pinMode(b2Pin, INPUT_PULLUP);
// read switches
b1 = digitalRead(b1Pin); // Read b1 button states
b2 = digitalRead(b2Pin); // Read b2 button states
YR_Process();
YR_States();
void YR_Process (){
switch (indState) {
case YELLOW_ON:
digitalWrite(redPin, HIGH);
digitalWrite(yellowPin, LOW); // Yellow ON
break ;
case RED_ON:
digitalWrite(redPin, LOW); // Red ON
digitalWrite(yellowPin, HIGH);
break ;
case NONE:
break ;
void YR_States(){
if (b1 == LOW){ // b1 button pressed
indState = YELLOW_ON;
else {
indState = RED_ON; // b1 button released
if (b2 == LOW){ // b2 button pressed
if (indState = RED_ON){
indState = NONE; // RED light turns OFF !
void Sleep() { // Set ALL 2 lights turn OFF
b2 buton (closed/pressed) when the pointer hits b2 to turn OFF the RED light. The RED light continues turning OFF after the pointer changes direction: b2 opened/released as Initial state (YELLOW and RED lights: OFF, b1 and b2 button: opened).
Just simplify, I have removed the statement: if (indState == RED_ON) {...} from the program.
The program is OK at b1 button position. It can make Yellow light:ON when b1 closed, and Red light: ON (yellow: OFF) when b1 opened.
But I don't know HOW to make the Red light: OFF after the pointer hits b2 button and release, meaning the program goto initial state where the Yellow&Red lights: OFF, b1&b2 buttons: OPENED as the beginning.
Thanks for your advice,
Here is the code updated:
* Arduino Uno R3
* 2 pushed buttons (b1, b2) + 2 lights (Yellow, Red)
} indState;
// read switches
YR_Process();
YR_States();
void YR_Process (){
switch (indState) {
case YELLOW_ON:
break ;
case RED_ON:
break ;
case NONE:
break ;
void YR_States(){
if (b1 == LOW){ // b1 button pressed, yellow light turns ON
else {
indState = RED_ON; // b1 button released, yellow light turns OFF, red light turns ON immidiately
indState = NONE; // RED light turns OFF at the moment b2 is hits/pressed by pointer.
It would have been better if you answered Tom's diagram with another diagram. It really helps to see it in a picture.
I think I understand your request in replies 11 and 12 to mean that it can only enter the red state if it was yellow previously. Then the code would look like this...
else if (indState == YELLOW_ON) {
