Hi
I have trouble to find a datasheet and a correct pinout for this board. Google tells me that the pinout I find from Liligo has been wrong.
Due to massive use of ports in my project I strugle to get things to work.
Can any of you help me with a correct datasheet and or pinout.
Here is my needs for pins, and pic of board for info:
Thanks up front
ua6em
April 27, 2023, 5:48pm
2
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <stdint.h>
#define EXTERNAL_NUM_INTERRUPTS 16
#define NUM_DIGITAL_PINS 40
#define NUM_ANALOG_INPUTS 16
#define analogInputToDigitalPin(p) (((p)<20)?(analogChannelToDigitalPin(p)):-1)
#define digitalPinToInterrupt(p) (((p)<40)?(p):-1)
#define digitalPinHasPWM(p) (p < 34)
// I2C OLED Display works with SSD1306 driver
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
// SPI LoRa Radio
#define LORA_SCK 5 // GPIO5 - SX1276 SCK
#define LORA_MISO 19 // GPIO19 - SX1276 MISO
#define LORA_MOSI 27 // GPIO27 - SX1276 MOSI
#define LORA_CS 18 // GPIO18 - SX1276 CS
#define LORA_RST 14 // GPIO14 - SX1276 RST
#define LORA_IRQ 26 // GPIO26 - SX1276 IRQ (interrupt request)
static const uint8_t LED_BUILTIN = 2;
#define BUILTIN_LED LED_BUILTIN // backward compatibility
#define LED_BUILTIN LED_BUILTIN
static const uint8_t KEY_BUILTIN = 0;
static const uint8_t TX = 1;
static const uint8_t RX = 3;
static const uint8_t SDA = 21;
static const uint8_t SCL = 22;
static const uint8_t SS = 18;
static const uint8_t MOSI = 27;
static const uint8_t MISO = 19;
static const uint8_t SCK = 5;
static const uint8_t A0 = 36;
static const uint8_t A1 = 37;
static const uint8_t A2 = 38;
static const uint8_t A3 = 39;
static const uint8_t A4 = 32;
static const uint8_t A5 = 33;
static const uint8_t A6 = 34;
static const uint8_t A7 = 35;
static const uint8_t A10 = 4;
static const uint8_t A11 = 0;
static const uint8_t A12 = 2;
static const uint8_t A13 = 15;
static const uint8_t A14 = 13;
static const uint8_t A15 = 12;
static const uint8_t A16 = 14;
static const uint8_t A17 = 27;
static const uint8_t A18 = 25;
static const uint8_t A19 = 26;
static const uint8_t T0 = 4;
static const uint8_t T1 = 0;
static const uint8_t T2 = 2;
static const uint8_t T3 = 15;
static const uint8_t T4 = 13;
static const uint8_t T5 = 12;
static const uint8_t T6 = 14;
static const uint8_t T7 = 27;
static const uint8_t T8 = 33;
static const uint8_t T9 = 32;
static const uint8_t DAC1 = 25;
static const uint8_t DAC2 = 26;
#endif /* Pins_Arduino_h */
horace
April 28, 2023, 8:32am
3
have you tested basic device, e.g. is this LilyGO/TTGO-LORA32 your device? if not can you give a link to the device?
dolloc
June 16, 2023, 4:40pm
4
Good morning,
I am using a TTGO Lora T3_V1.6.1 board and I would like to connect a second Nokia 5110 display that works with SPI. The connection is impossible which pins should I use?
dolloc
June 17, 2023, 6:52am
5
Anglais
I tested all the configuration using the pins available for the SD card (which I don't use) but it still doesn't work.
I use the Adafruit PCD8544 library which allows you to configure the connection. For example I tested the pins: RST=34, CS=12, DC=35,DIN=15, CLK=14.
here is a qood video regarding esp32 pins
Andreas Spiess
He mention how to use 2 x SPI busses
dolloc
June 17, 2023, 3:16pm
7
Thanks for the link, but I can't find the solution.
Not all pins are accessible with the LILYGO Lora module.
