I have an Arduino Lilypad with this simple code where I try to write a simple message to the serial console. The baud rate is set to 9600 both in the code as well as in the serial console and I'm using the FTDI UART tool. However, the output I'm receiving is corrupted and I'm not sure what could be the cause. Any ideas or suggestions are welcome. Thanks!
yes, I'm able to load the program into the Arduino without issues. Also, in my example code, there's a LED blinking which works as supposed. Also, on the FTDI tool, I can see the TX, RX LEDs blinking whenever a message is being sent. So assume it's just something with the wrong configuration
it's quite an old one indeed. It's been laying around in my drawer for a couple of years and recently I found it and thought I would give it a try.
Is there something I can do with it or is it useless?
