Limit switch coding
Hi there.
I'm a CNC programmer by trade. I'm pretty new to coding the Arduino.
I am writing a prog to run two DC motors as a simple power feed set up for my manual milling machine at home. Yes I could use steppers but I love the challenge/learning the hard way. I also have some big DC motors on hand and understand PWM and H Bridge Drivers. Ultimately I will add encoders and go full CNC.
In my setup I have the main loop as Joy Stick Jog. Interrupt Pin 1 is the Power Feed Mode and Interrupt Pin 2 will be Incremental Jog but I haven't cracked multi button Debounce/State Change yet but I will soon.
The problem I am having is I am trying to add limit switches the the Joy Stick Mode initially. I have the switch set up to Pin 23 on the Mega and is giving me the correct output in the Serial Monitor......when pressed Pin 23 goes LOW.
When I include this as an && in my IF Statement and I press it it shows LOW as expected but When I move the Joy Stick the motor still turns and the PIN 23 is driven HIGH in the serial. What is causing it to go HIGH when I command the motor to turn?
int LimitX = digitalRead(LimitXpos);
if ((inputXValue < 470) && (LimitX = HIGH)) {
digitalWrite(directionX, HIGH);
outputXValue = map(inputXValue, 470, 0, 0, 5);
I hope this makes some kind of sense?
This is my first post ever BTW
Many thanks if you can help?
Barney
You are setting LimitX to HIGH instead of testing its value
== is a comparison, = is an assignment.
Steve
Mate......
Awesome......!!!!
What plonker
